172 Personne(s) en ligne (139 Personne(s) connectée(s) sur Forum)
Invité(s): 172
tableau de bord lisse
Post(s): 6
bsr a tous voila j'aimerai eventuellement oter le simili gris fonce du haut de tableau de bord pour le lisser. mais qu'y a t'il dessous? si qq a deja demonte ou si ca se vend en fibre...
merci d'avance.
par la meme occasion meme question pour les panneaux de porte avant
Contribution le : 29/04/2011 19:29
Re: tableau de bord lisse
Quelqu'un a déjà fait cela ... Fais une recherche...
Contribution le : 30/04/2011 08:32
Contribution le : 30/04/2011 11:38
0.000089 - SET NAMES 'utf8'
0.000517 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.002903 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '07d002d1beaea21b2764dabec483d7bb'
0.000179 - SELECT * FROM modules WHERE dirname = 'newbb'
0.002027 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000497 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000273 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 284484
0.000164 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000987 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000938 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000976 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000179 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 14507
0.000110 - SELECT * FROM bb_topics WHERE topic_id=14507
0.000150 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=14507 AND approved = 1
0.000124 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=14507 AND approved = 1 AND post_id < 284484
0.000218 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=14507 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000159 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =14507
0.000252 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.001064 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000519 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000251 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000788 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000123 - SELECT * FROM groups
0.000358 - SELECT * FROM bb_forums ORDER BY forum_order
0.000199 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000301 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000222 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.21.76.0'
0.000126 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1714123590, '3.21.76.0', 5)
0.000155 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000442 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.21.76.0'
0.000137 - UPDATE online SET online_updated=1714123590, online_module = 5 WHERE online_uid = 0 AND online_ip='3.21.76.0'
0.000133 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.21.76.0'
0.000106 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1714123590, '3.21.76.0', 6, 14507)
0.001439 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('54.36.148.55','54.36.148.223','207.46.13.6','207.46.13.126','54.36.148.56','54.36.149.62','54.36.148.206','54.36.148.150','54.36.148.14','54.36.148.197','54.36.148.166','54.36.149.68','54.36.148.111','54.36.148.34','54.36.148.38','54.36.148.12','54.36.148.47','54.36.148.228','54.36.149.11','54.36.149.96','54.36.148.227','54.36.148.152','54.36.149.79','54.36.148.9','40.77.167.143','54.36.148.107','54.36.148.72','54.36.148.207','54.36.149.43','54.36.149.49','54.36.148.247','54.36.149.87','54.36.148.95','54.36.149.19','54.36.148.175','110.249.201.159','54.36.148.226','54.36.148.198','54.36.148.83','54.36.148.76','54.36.149.8','54.36.148.10','54.36.149.1','54.36.148.191','54.36.148.145','54.36.149.23','54.36.148.232','54.36.149.65','54.36.148.48','54.36.149.9','54.36.148.84','54.36.148.255','54.36.148.130','54.36.148.236','54.36.149.53','54.36.148.136','54.36.148.244','54.36.148.73','54.36.148.252','54.36.148.66','54.36.149.59','54.36.148.33','54.36.149.85','18.221.141.44','54.36.149.48','54.36.149.22','54.36.148.215','47.128.17.133','54.36.149.18','54.36.148.16','54.36.149.89','54.36.148.235','54.36.148.183','54.36.148.230','54.36.149.34','144.76.23.206','3.142.197.198','54.36.148.96','54.36.148.3','54.36.149.30','54.36.148.68','54.36.148.131','54.36.148.90','54.36.148.127','54.36.149.67','54.36.149.44','54.36.148.225','54.36.149.72','3.21.76.0','54.36.148.170','54.36.148.192','54.36.148.122','54.36.148.243','54.36.149.101','54.36.148.148','85.208.96.212','54.36.148.240','54.36.148.157','111.225.148.177','54.36.149.38','54.36.148.210','54.36.148.220','54.36.149.102','54.36.148.253','54.36.148.98','54.36.149.26','54.36.148.102','85.208.96.197','54.36.149.91','54.36.148.26','54.36.149.31','54.36.148.100','54.36.149.98','54.36.148.46','54.36.148.94','54.36.148.54','54.36.149.39','54.36.148.40','54.36.148.109','18.117.216.229','54.36.149.29','54.36.149.50','54.36.148.205','54.36.149.92','54.36.149.105','85.208.96.206','54.36.148.242','54.36.148.24','154.194.16.194','54.36.148.89','54.36.148.151','54.36.148.171','54.36.149.56','3.128.199.210','52.167.144.232','54.36.148.208','54.36.148.30','54.36.148.222','54.36.148.234') )
0.000156 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '14507'
0.000129 - SELECT * FROM bb_online WHERE (online_topic = '14507' AND online_uid <> '0')
0.000275 - SELECT * FROM `users` WHERE uid IN (6008,1779,841)
0.000159 - SELECT * FROM bb_online WHERE online_uid IN (6008,1779,841)
0.000172 - SELECT groupid FROM groups_users_link WHERE uid=6008
0.000158 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 6 AND rank_max >= 6 AND rank_special = 0
0.000108 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000104 - SELECT * FROM smiles
0.000203 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000085 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
0.000184 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000175 - SELECT post_id FROM bb_posts WHERE topic_id = 14507 AND pid = 0
0.000355 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Usage de la mémoire: 8224144 bytes
XOOPS a mis 0.223 seconde(s) pour charger
