192 Personne(s) en ligne (177 Personne(s) connectée(s) sur Forum)
Invité(s): 192
différenciel sur ph1
Oui oui bien évidemment!
T'as recu mon mp ?
Le lien ne fonctionne pas.
ohh c'est beau ça
Récape a faire...
Installation des 3 mano VDO
0.000114 - SET NAMES 'utf8'
0.000914 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '9413d3e10264055952e73edf507398b7'
0.000273 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 353410
0.000099 - SELECT * FROM bb_forums WHERE forum_id = 23
0.000250 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '23' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000225 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 5629
0.000100 - SELECT * FROM bb_topics WHERE topic_id=5629
0.000027 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1
0.005478 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1 AND post_id < 353410
0.000190 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=5629 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 1800, 30
0.000159 - SELECT * FROM bb_forums ORDER BY forum_order
0.000223 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000432 - UPDATE online SET online_updated=1792772465, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000338 - SELECT * FROM online
0.000494 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000206 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000439 - UPDATE online SET online_updated=1792772465, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000144 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000257 - UPDATE bb_online SET online_updated= '1792772465', online_forum = '23', online_topic = '5629' WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.001473 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('169.1.203.187','207.32.153.181','191.102.139.211','39.39.143.127','86.186.254.224','197.255.197.252','104.165.161.75','185.191.171.19','196.189.18.104','85.208.96.196','179.6.26.45','93.152.52.50','223.185.46.189','189.104.204.122','174.140.218.153','31.105.125.159','65.18.213.105','145.82.109.241','195.40.125.118','212.79.110.67','190.92.216.101','49.43.163.228','94.142.18.136','45.225.237.205','196.190.208.170','72.63.71.41','93.21.100.90','72.63.19.39','45.171.182.3','217.227.54.56','186.236.195.64','168.222.34.233','123.31.178.101','186.179.170.195','88.173.241.7','104.164.250.62','102.209.18.58','64.52.27.183','185.191.171.15','85.208.96.197','85.208.96.201','45.93.96.232','103.190.47.77','212.95.147.107','103.170.81.137','49.47.140.240','72.63.249.38','177.214.165.184','207.32.129.51','104.253.129.77','31.145.211.118','177.73.205.198','172.121.255.193','115.40.204.74','46.196.120.71','189.81.5.159','104.252.7.45','185.191.171.16','153.117.39.46','189.104.241.240','165.162.68.112','84.115.237.64','93.152.77.137','27.60.166.16','47.189.59.249','47.11.16.33','152.232.241.19','139.47.64.19','131.196.76.131','102.100.98.123','216.73.217.110','152.56.144.200','189.104.241.109','153.117.1.125','172.252.5.159','176.20.211.43','197.118.128.38','178.133.129.237','213.130.78.102','104.165.210.170','92.118.13.10','88.99.95.199','64.52.26.108','66.249.69.66','89.141.164.0','180.153.197.220','39.63.78.174','191.102.139.145','192.145.68.99','2.79.130.121','52.167.144.173','172.121.43.41','85.208.96.211','188.138.209.207','86.171.115.55','169.224.107.173','213.149.51.180','69.160.102.200','59.178.71.12','37.65.161.11','2.75.83.1','216.98.213.220','85.154.179.198','59.178.60.156','116.71.160.203','176.20.210.64','38.25.52.162','185.191.171.13','174.140.218.151','14.191.24.95','197.17.87.234','185.191.171.14','172.121.38.222','116.97.104.39','85.208.96.209','14.173.225.58','104.164.101.125','38.226.220.6','223.188.133.121','193.34.225.147','37.212.59.73','45.251.4.46','179.127.253.32','154.255.1.240','62.205.196.37','157.49.66.192','172.121.96.115','188.50.118.110','40.77.167.41','85.208.96.200','189.104.35.58','92.145.103.246','79.177.141.153','185.191.171.1','72.63.70.3','104.165.210.72','183.182.117.137','152.231.25.11','102.209.222.33','185.191.171.4','176.42.174.84','179.26.177.174','176.20.210.57','131.222.230.60','64.52.27.107','94.73.26.13','190.163.15.39','172.121.38.57','185.191.171.9','136.158.57.237','172.120.139.62','161.0.2.75','223.181.40.253','104.164.118.11','61.6.236.22','45.4.84.246','142.181.189.68','76.67.32.157','185.191.171.7','69.17.18.178','47.231.21.174','85.208.96.199','186.7.64.209','79.177.143.159','93.184.149.13','5.77.201.149','45.173.197.78','195.40.125.7','27.123.173.68','77.244.183.179','85.208.96.210','190.212.125.48','189.81.3.186','134.249.13.182','197.27.100.125','185.24.60.109','190.131.214.243') )
0.000188 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '5629'
0.000142 - SELECT * FROM bb_online WHERE (online_topic = '5629' AND online_uid <> '0')
0.000098 - SELECT * FROM `users` WHERE uid IN (1611,21,4383,841,1315,4050)
0.000229 - SELECT * FROM bb_online WHERE online_uid IN (1611,21,4383,841,1315,4050)
0.000046 - SELECT groupid FROM groups_users_link WHERE uid=1611
0.000029 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1547 AND rank_max >= 1547 AND rank_special = 0
0.000079 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000071 - SELECT groupid FROM groups_users_link WHERE uid=4383
0.000071 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000073 - SELECT groupid FROM groups_users_link WHERE uid=4050
0.000130 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000037 - SELECT post_id FROM bb_posts WHERE topic_id = 5629 AND pid = 0
0.000152 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 56
Usage de la mémoire: 9888576 bytes
XOOPS output init a mis 0.032 seconde(s) pour charger
Module display a mis 0.089 seconde(s) pour charger
