192 Personne(s) en ligne (180 Personne(s) connectée(s) sur Forum)
Invité(s): 192
différenciel sur ph1
Oui oui bien évidemment!
T'as recu mon mp ?
Le lien ne fonctionne pas.
ohh c'est beau ça
Récape a faire...
Installation des 3 mano VDO
0.000102 - SET NAMES 'utf8'
0.000805 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '9f195bac751bf440813779b0a7f8ba57'
0.000124 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000315 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 353729
0.000102 - SELECT * FROM bb_forums WHERE forum_id = 23
0.000057 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '23' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000040 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 5629
0.000021 - SELECT * FROM bb_topics WHERE topic_id=5629
0.000023 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1
0.005720 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1 AND post_id < 353729
0.000054 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=5629 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 1800, 30
0.000083 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000238 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.001458 - UPDATE online SET online_updated=1792772338, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000195 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000573 - UPDATE online SET online_updated=1792772338, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000164 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.001083 - UPDATE bb_online SET online_updated= '1792772338', online_forum = '23', online_topic = '5629' WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.001591 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('104.252.209.45','185.97.94.133','191.102.139.211','39.39.143.127','31.46.246.138','69.17.18.155','197.255.197.252','172.252.120.75','185.191.171.19','196.189.18.104','85.208.96.196','179.6.26.45','31.180.131.219','170.103.116.140','223.185.46.189','189.104.204.122','174.140.218.153','31.105.125.159','65.18.213.105','74.7.241.29','145.82.109.241','195.40.125.118','212.79.110.67','190.92.216.101','143.105.152.121','196.190.208.170','72.63.71.41','93.21.100.90','72.63.19.39','38.254.46.155','195.178.116.44','106.219.151.124','200.123.237.81','82.102.46.170','78.177.170.188','207.32.135.104','102.209.18.58','201.183.58.120','64.52.27.183','185.191.171.15','85.208.96.197','85.208.96.201','45.93.96.232','41.82.12.28','189.81.192.22','103.170.81.137','49.47.140.240','177.214.165.184','174.141.172.161','115.40.204.74','46.196.120.71','38.63.85.112','161.0.2.188','185.191.171.16','153.117.39.46','189.104.241.240','165.162.68.112','84.115.237.64','93.152.77.137','27.60.166.16','85.208.96.194','47.15.242.173','119.148.103.161','76.204.96.170','191.7.97.73','176.20.210.77','212.58.120.157','63.246.149.182','216.73.217.110','152.56.144.200','189.104.241.109','153.117.1.125','172.252.5.159','176.20.211.43','197.118.128.38','178.133.129.237','213.130.78.102','104.165.210.170','92.118.13.10','88.99.95.199','94.241.6.250','85.208.96.206','89.141.164.0','180.153.197.220','39.63.78.174','191.102.139.145','192.145.68.99','2.79.130.121','52.167.144.173','172.121.43.41','38.253.151.136','85.208.96.211','101.186.154.247','179.109.172.52','213.149.51.180','69.160.102.200','59.178.71.12','37.65.161.11','2.75.83.1','43.155.75.213','176.20.211.64','147.235.219.206','174.140.218.183','5.45.139.130','49.47.196.138','152.59.3.112','95.190.132.93','116.71.160.203','176.20.210.64','38.25.52.162','185.191.171.13','174.140.218.151','156.207.37.228','172.121.96.83','185.191.171.14','172.121.38.222','103.136.59.170','181.52.38.185','185.191.171.3','110.139.128.57','85.208.96.209','14.173.225.58','104.164.101.125','172.252.5.46','189.81.5.233','64.119.27.92','178.215.165.158','154.255.1.240','62.205.196.37','157.49.66.192','172.121.96.115','49.230.79.188','188.50.118.110','40.77.167.41','162.251.172.172','81.84.253.59','72.63.70.3','37.99.66.99','152.231.25.11','83.83.146.227','105.157.130.77','150.228.211.97','176.42.174.84','179.26.177.174','176.20.210.57','102.164.172.223','157.100.186.13','196.191.121.230','190.163.15.39','172.121.38.57','185.191.171.9','136.158.57.237','172.120.139.62','161.0.2.75','223.181.40.253','104.164.118.11','61.6.236.22','45.4.84.246','142.181.189.68','76.67.32.157','185.191.171.7','69.17.18.178','185.191.171.6','47.231.21.174','64.52.26.1','166.114.175.108','79.177.143.159','185.191.171.4','45.173.197.78','195.40.125.7','27.123.173.68','83.167.40.95','85.208.96.210','189.81.2.150','175.100.48.141','105.190.108.127','104.164.59.109','143.105.35.56','172.120.139.87','85.208.96.193') )
0.000182 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '5629'
0.000208 - SELECT * FROM bb_online WHERE (online_topic = '5629' AND online_uid <> '0')
0.000109 - SELECT * FROM `users` WHERE uid IN (1611,21,4383,841,1315,4050)
0.000221 - SELECT * FROM bb_online WHERE online_uid IN (1611,21,4383,841,1315,4050)
0.000071 - SELECT groupid FROM groups_users_link WHERE uid=1611
0.000040 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1547 AND rank_max >= 1547 AND rank_special = 0
0.000079 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000079 - SELECT groupid FROM groups_users_link WHERE uid=4383
0.000078 - SELECT groupid FROM groups_users_link WHERE uid=4050
0.000099 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000161 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 56
Usage de la mémoire: 9888144 bytes
XOOPS a mis 0.156 seconde(s) pour charger
