117 Personne(s) en ligne (99 Personne(s) connectée(s) sur Forum)
Invité(s): 117
Petite précision decrantage 1.6e
De savoie
Post(s): 183
Salut, je veux decranter mon auto moi aussi , j'ai un 1.6 et les trains arrière son différents des cab et 2.0l, je voulai savoir si il y a des particularité à savoir? Sachant que la méthode reste identique !
Merci à vous.
Contribution le : 27/06/2017 11:37
Re: Petite précision decrantage 1.6e
salut,
Exactement pareil , pas de soucis de ce coté
Contribution le : 28/06/2017 07:05
De savoie
Post(s): 183
Nikel merci
Contribution le : 28/06/2017 07:35
0.000143 - SET NAMES 'utf8'
0.001572 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '6af869a1e5570df0ed90faaab6253bf3'
0.000524 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 377165
0.000063 - SELECT * FROM bb_forums WHERE forum_id = 10
0.000046 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '10' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000428 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20698
0.000177 - SELECT * FROM bb_topics WHERE topic_id=20698
0.000042 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20698 AND approved = 1
0.000306 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20698 AND approved = 1 AND post_id < 377165
0.000669 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20698 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000458 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20698
0.000065 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000254 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000209 - UPDATE online SET online_updated=1792738760, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000239 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000215 - UPDATE online SET online_updated=1792738761, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000156 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000148 - UPDATE bb_online SET online_updated= '1792738761', online_forum = '10', online_topic = '20698' WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000878 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('104.252.7.183','197.26.43.246','67.84.146.69','185.191.171.14','89.85.120.234','172.252.127.63','187.3.226.12','104.253.130.34','81.65.90.21','140.206.235.55','207.32.139.220','85.208.96.195','85.208.96.196','172.120.249.119','104.165.161.221','64.52.25.173','72.63.71.229','189.216.116.141','95.26.250.148','172.121.37.183','45.232.17.243','185.191.171.5','104.252.209.41','216.73.217.110','207.32.153.30','74.7.241.29','185.191.171.18','187.95.168.84','104.252.229.246','124.83.75.8','181.46.112.163','172.252.120.108','182.8.122.243','185.191.171.13','85.208.96.203','158.47.200.135','37.231.33.16','84.37.118.150','104.164.101.47','138.204.211.39','89.138.216.105','176.20.210.66','177.191.226.227','185.191.171.8','220.181.108.90','105.109.135.54','116.98.245.208','74.98.189.73','189.104.35.201','83.167.40.95','207.32.156.234','45.93.96.236','50.60.96.134','213.177.206.225','88.169.245.253','185.191.171.11','45.93.96.34','80.116.4.123','64.52.26.156','172.121.11.217','172.121.38.216','102.97.15.125','138.204.79.235','104.253.129.110','23.108.72.15','207.32.153.184','104.253.129.93','172.120.139.229','196.75.190.168','85.208.96.210','186.189.103.237','85.208.96.212','147.235.221.152','64.52.26.87','64.52.27.59','85.208.96.202','41.140.209.88','64.52.26.116','172.121.43.120','185.191.171.2','189.104.204.82','189.104.204.191','185.191.171.9','104.252.94.13','179.37.5.94','37.76.9.168','66.231.79.28','185.191.171.7','191.243.36.151','185.191.171.16','171.61.169.17','85.208.96.211','189.104.34.63','201.187.255.180','191.102.139.52','23.108.72.82','177.66.140.145','87.121.9.175','72.63.72.205') )
0.000165 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20698'
0.000119 - SELECT * FROM bb_online WHERE (online_topic = '20698' AND online_uid <> '0')
0.000066 - SELECT * FROM `users` WHERE uid IN (26563,4383)
0.000141 - SELECT * FROM bb_online WHERE online_uid IN (26563,4383)
0.000057 - SELECT groupid FROM groups_users_link WHERE uid=26563
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 183 AND rank_max >= 183 AND rank_special = 0
0.000059 - SELECT groupid FROM groups_users_link WHERE uid=4383
0.000074 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000026 - SELECT post_id FROM bb_posts WHERE topic_id = 20698 AND pid = 0
Total: 49
Usage de la mémoire: 8168600 bytes
XOOPS Boot a mis 0.026 seconde(s) pour charger
XOOPS output init a mis 0.089 seconde(s) pour charger
Page rendering a mis 0.143 seconde(s) pour charger
