133 Personne(s) en ligne (91 Personne(s) connectée(s) sur Forum)
Invité(s): 133
Petite précision decrantage 1.6e
De savoie
Post(s): 183
Salut, je veux decranter mon auto moi aussi , j'ai un 1.6 et les trains arrière son différents des cab et 2.0l, je voulai savoir si il y a des particularité à savoir? Sachant que la méthode reste identique !
Merci à vous.
Contribution le : 27/06/2017 11:37
Re: Petite précision decrantage 1.6e
salut,
Exactement pareil , pas de soucis de ce coté
Contribution le : 28/06/2017 07:05
De savoie
Post(s): 183
Nikel merci
Contribution le : 28/06/2017 07:35
0.000182 - SET NAMES 'utf8'
0.000875 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '4ad433e85f0ee52cd7ca0a01b9e73255'
0.002322 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 377170
0.000073 - SELECT * FROM bb_forums WHERE forum_id = 10
0.000072 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '10' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000227 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20698
0.000152 - SELECT * FROM bb_topics WHERE topic_id=20698
0.000184 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20698 AND approved = 1
0.000490 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20698 AND approved = 1 AND post_id < 377170
0.000373 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20698 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.001366 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20698
0.000134 - SELECT * FROM bb_forums ORDER BY forum_order
0.000245 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000944 - UPDATE online SET online_updated=1792741726, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000538 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000198 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000659 - UPDATE online SET online_updated=1792741726, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000152 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.001129 - UPDATE bb_online SET online_updated= '1792741726', online_forum = '10', online_topic = '20698' WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000784 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('189.104.35.57','185.191.171.11','185.191.171.1','166.48.111.163','37.67.46.189','66.249.69.68','216.73.217.110','52.167.144.169','72.63.72.78','40.77.167.42','220.181.108.177','104.165.161.92','104.164.251.131','45.114.134.189','187.33.204.64','176.214.13.223','192.178.7.65','185.191.171.14','192.178.7.66','191.102.139.122','38.17.164.246','185.191.171.5','189.81.192.52','173.47.90.204','189.81.3.237','195.40.169.185','172.252.127.54','216.10.217.122','172.121.254.241','88.172.91.219','84.108.109.96','161.0.2.133','189.51.203.109','104.165.187.244','190.89.98.175','144.76.23.207','192.177.105.21','85.208.96.201','189.81.70.131','185.191.171.4','197.241.72.208','185.191.171.12','107.77.104.22','179.108.79.156','191.102.139.213','85.208.96.199','185.191.171.7','86.225.186.137','197.186.3.111','181.214.168.98','220.181.108.159','104.253.10.177','104.252.38.183','104.252.94.139','85.208.96.197','195.209.187.245','77.98.146.41','104.253.129.172','185.191.171.19','174.140.218.250','185.191.171.6','85.208.96.206','85.208.96.198','104.252.38.124','104.253.135.222','201.227.135.248','104.253.160.101','104.252.229.159','66.249.69.67','185.191.171.9','161.0.2.9','172.121.11.125','172.121.255.99','172.121.38.34','189.104.240.85','172.252.127.156','174.140.218.68','45.38.10.178','104.164.250.176','185.191.171.3','189.104.34.66','172.59.229.166','171.96.74.236','189.81.4.218','172.121.254.222','172.252.120.212','37.65.63.52','187.19.50.15','85.208.96.203','104.164.251.161','64.52.24.45') )
0.000199 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20698'
0.000205 - SELECT * FROM bb_online WHERE (online_topic = '20698' AND online_uid <> '0')
0.000227 - SELECT * FROM `users` WHERE uid IN (26563,4383)
0.000112 - SELECT * FROM bb_online WHERE online_uid IN (26563,4383)
0.000070 - SELECT groupid FROM groups_users_link WHERE uid=26563
0.000040 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 183 AND rank_max >= 183 AND rank_special = 0
0.000073 - SELECT groupid FROM groups_users_link WHERE uid=4383
0.000051 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000184 - SELECT post_id FROM bb_posts WHERE topic_id = 20698 AND pid = 0
0.002110 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 49
Usage de la mémoire: 8168640 bytes
XOOPS a mis 0.263 seconde(s) pour charger
Page rendering a mis 0.158 seconde(s) pour charger
