162 Personne(s) en ligne (130 Personne(s) connectée(s) sur Forum)
Invité(s): 162
Pignon moteur capote
Post(s): 28
Bonjour je suis un peu embêter je recherche un pignon pour moteur hydraulique de capote sur le tutoriel il dit d aller chez renault mais renault me dit que sa ne se fait plus du coup ou puis je en trouver un ou comment réparée merci d avance
Contribution le : 30/04/2018 08:07
Re: Pignon moteur capote
Post(s): 111
Contribution le : 30/04/2018 08:17
Post(s): 28
Contribution le : 30/04/2018 08:24
0.000160 - SET NAMES 'utf8'
0.000233 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001127 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '7570c2eb4ece2ec44bcecaa445d7e77c'
0.000334 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 378778
0.000078 - SELECT * FROM bb_forums WHERE forum_id = 11
0.000032 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '11' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000394 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20949
0.000182 - SELECT * FROM bb_topics WHERE topic_id=20949
0.000028 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20949 AND approved = 1
0.000263 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20949 AND approved = 1 AND post_id < 378778
0.000181 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20949 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000684 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20949
0.000026 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000186 - SELECT * FROM bb_forums ORDER BY forum_order
0.000147 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000303 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000260 - UPDATE online SET online_updated=1789931299, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000257 - SELECT * FROM online
0.000260 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000501 - UPDATE online SET online_updated=1789931299, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000190 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000777 - UPDATE bb_online SET online_updated= '1789931299', online_forum = '11', online_topic = '20949' WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000438 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001145 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('37.155.57.184','66.249.79.3','34.122.252.130','136.116.59.242','34.28.137.40','146.148.110.159','34.132.249.233','35.202.107.105','104.198.177.225','93.41.35.26','35.192.48.46','104.198.47.65','66.80.38.1','40.77.167.59','34.135.220.83','85.208.96.196','34.9.203.105','40.77.167.158','104.198.16.217','34.29.229.26','45.65.79.117','89.109.51.250','45.161.238.71','35.232.21.128','35.222.110.111','34.55.37.33','35.255.247.90','34.9.180.63','34.171.232.236','88.229.71.83','34.30.233.192','34.10.108.251','34.10.84.36','104.155.129.90','35.224.103.75','73.226.129.115','34.28.60.93','34.55.56.100','136.112.32.154','34.135.218.57','34.66.127.248','136.114.7.39','34.9.131.229','35.226.83.174','213.110.66.117','94.254.128.12','34.31.187.131','34.16.86.184','104.197.166.106','34.57.115.209','35.193.156.72','34.30.52.134','35.254.195.237','136.114.190.91','85.208.96.195','136.115.172.248','52.167.144.160','34.68.177.213','34.173.48.161','34.27.43.36','136.119.87.190','34.28.30.77','35.255.232.183','34.27.99.191','167.250.109.175','40.77.167.48','51.75.236.151','35.202.95.134','136.114.178.72','35.226.113.131','35.226.94.124','35.192.131.166','35.222.231.60','34.66.45.93','136.119.214.88','35.254.201.217','177.223.245.72','131.221.194.101','34.133.237.161','136.113.248.41','85.208.96.197','35.254.25.136','85.208.96.210','34.172.78.224','34.44.37.232','35.222.247.211','35.188.85.51','141.226.92.195','34.42.103.145','35.253.40.20','34.27.24.113','213.186.155.35','34.123.129.208','49.0.7.247','35.226.130.30','66.249.68.194','34.42.190.171','34.44.229.100','220.181.108.156','85.208.96.206','34.63.146.186','136.115.16.60','34.134.224.139','34.31.108.231','35.254.55.111','136.65.144.175','34.31.207.226','92.222.104.216','136.64.93.95','216.73.217.83','34.30.230.50','66.249.68.193','34.67.235.108','34.27.103.20','66.249.68.192','205.188.126.9','34.59.183.133','34.41.65.37','34.133.188.217','136.65.65.243','35.226.87.141','34.173.138.43','136.112.177.219','34.27.5.65','35.193.255.230','104.165.93.26','35.193.15.59','35.225.182.77','136.65.57.107','34.31.12.118') )
0.000213 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20949'
0.000171 - SELECT * FROM bb_online WHERE (online_topic = '20949' AND online_uid <> '0')
0.000094 - SELECT * FROM `users` WHERE uid IN (27447,27059)
0.000135 - SELECT * FROM bb_online WHERE online_uid IN (27447,27059)
0.000050 - SELECT groupid FROM groups_users_link WHERE uid=27447
0.000029 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 28 AND rank_max >= 28 AND rank_special = 0
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=27059
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 111 AND rank_max >= 111 AND rank_special = 0
0.000026 - SELECT post_id FROM bb_posts WHERE topic_id = 20949 AND pid = 0
0.000062 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 49
Usage de la mémoire: 8164840 bytes
XOOPS a mis 0.141 seconde(s) pour charger
