102 Personne(s) en ligne (60 Personne(s) connectée(s) sur Forum)
Invité(s): 102
Pignon moteur capote
Post(s): 28
Bonjour je suis un peu embêter je recherche un pignon pour moteur hydraulique de capote sur le tutoriel il dit d aller chez renault mais renault me dit que sa ne se fait plus du coup ou puis je en trouver un ou comment réparée merci d avance
Contribution le : 30/04/2018 08:07
Re: Pignon moteur capote
Post(s): 111
Contribution le : 30/04/2018 08:17
Post(s): 28
Contribution le : 30/04/2018 08:24
0.000182 - SET NAMES 'utf8'
0.001421 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'cd8431181b43a6c966b81d36212ae9fc'
0.000442 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 378779
0.000157 - SELECT * FROM bb_forums WHERE forum_id = 11
0.000167 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000172 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000173 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '11' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000522 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20949
0.000247 - SELECT * FROM bb_topics WHERE topic_id=20949
0.000565 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20949 AND approved = 1
0.000881 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20949 AND approved = 1 AND post_id < 378779
0.000501 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20949 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.001371 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20949
0.000206 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000078 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000407 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000775 - UPDATE online SET online_updated=1793907433, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000395 - SELECT * FROM online
0.000314 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000465 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000977 - UPDATE online SET online_updated=1793907434, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000253 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000722 - UPDATE bb_online SET online_updated= '1793907434', online_forum = '11', online_topic = '20949' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000344 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000975 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('108.6.148.69','144.76.23.194','171.252.225.175','168.167.18.189','51.174.15.124','193.104.126.69','206.180.143.95','85.208.96.211','93.170.185.63','185.191.171.19','45.225.91.109','185.191.171.11','213.230.87.196','157.55.39.205','102.208.120.145','5.183.255.39','179.6.23.166','202.46.61.111','80.217.238.224','66.249.70.192','188.22.100.251','103.72.190.198','89.147.166.138','83.167.40.95','170.168.29.55','102.223.157.229','40.77.167.24','31.134.2.41','85.208.96.205','39.101.88.165','186.169.63.72','216.73.216.84','213.188.176.57','87.95.116.69','185.191.171.6','196.238.106.114','185.191.171.14','66.249.64.8','50.117.107.184','185.191.171.12','80.68.109.42','87.241.158.243','185.191.171.2','69.94.45.234','186.179.68.20','62.217.141.166','31.134.7.68','188.167.251.243','185.191.171.16','86.15.111.84','196.115.25.161','190.122.176.6','178.51.137.190','185.191.171.10','216.234.223.110','173.34.128.251','85.117.228.153','74.125.210.196','185.191.171.13','103.147.106.41') )
0.000244 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20949'
0.000148 - SELECT * FROM bb_online WHERE (online_topic = '20949' AND online_uid <> '0')
0.000087 - SELECT * FROM `users` WHERE uid IN (27447,27059)
0.000203 - SELECT * FROM bb_online WHERE online_uid IN (27447,27059)
0.000058 - SELECT groupid FROM groups_users_link WHERE uid=27447
0.000049 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 28 AND rank_max >= 28 AND rank_special = 0
0.000055 - SELECT groupid FROM groups_users_link WHERE uid=27059
0.000045 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 111 AND rank_max >= 111 AND rank_special = 0
0.000062 - SELECT * FROM smiles
0.000123 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000379 - SELECT post_id FROM bb_posts WHERE topic_id = 20949 AND pid = 0
0.000207 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 49
Usage de la mémoire: 8175792 bytes
XOOPS a mis 0.301 seconde(s) pour charger
XOOPS output init a mis 0.086 seconde(s) pour charger
Page rendering a mis 0.095 seconde(s) pour charger
