216 Personne(s) en ligne (177 Personne(s) connectée(s) sur Forum)
Invité(s): 216
De Bouaye (44)
Post(s): 356
Post(s): 276
Post(s): 1410
sympa ces disques
ca va freiner
autant pour moi
non rien senti au retour.
sa te fait quoi comme bruit?
De Poitiers - 86
Post(s): 2118
De Poitiers - 86
Post(s): 2118
De Poitiers - 86
Post(s): 2118
0.000118 - SET NAMES 'utf8'
0.000708 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '846b20b745c9fcf57702e7992d0647e3'
0.000096 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000457 - SELECT * FROM bb_topics WHERE topic_id=3933
0.000087 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '23' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000596 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 3933
0.000034 - SELECT * FROM bb_topics WHERE topic_id=3933
0.000026 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3933 AND approved = 1
0.002505 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=3933 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 240, 30
0.000123 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000145 - SELECT * FROM bb_forums ORDER BY forum_order
0.000249 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000242 - UPDATE online SET online_updated=1789938082, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000258 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000165 - UPDATE online SET online_updated=1789938082, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000149 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000177 - UPDATE bb_online SET online_updated= '1789938082', online_forum = '23', online_topic = '3933' WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000291 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001566 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('37.228.224.100','85.208.96.205','34.28.137.40','34.31.108.231','185.191.171.3','35.184.229.62','85.208.96.195','185.191.171.7','35.226.130.30','34.45.53.200','104.155.129.90','85.208.96.194','34.132.30.84','220.181.108.167','35.193.255.230','34.172.179.139','34.10.138.17','104.252.250.26','104.252.211.163','187.73.200.163','186.12.184.26','116.206.97.63','37.214.32.4','35.232.208.144','34.56.106.168','34.28.219.45','85.208.96.209','35.255.220.188','136.112.177.219','34.134.185.175','35.255.232.183','34.27.90.241','34.42.190.171','34.44.37.232','136.112.237.154','34.135.218.57','34.41.65.37','136.114.190.91','59.153.86.53','35.188.85.51','34.173.48.161','136.115.172.248','90.251.31.37','136.115.148.7','104.198.47.65','34.67.161.204','34.132.249.233','34.172.85.78','34.41.163.232','34.71.205.180','185.50.206.181','35.255.247.90','34.9.203.105','34.172.174.93','104.154.87.0','35.226.83.174','35.225.182.77','34.135.220.83','67.83.33.148','35.238.73.253','34.67.235.108','35.254.201.217','136.115.98.185','35.226.190.245','66.249.79.5','34.30.230.50','66.249.68.192','34.55.37.33','115.164.94.230','35.222.231.60','34.29.246.143','35.224.103.75','136.114.251.171','34.42.103.145','34.41.18.53','146.148.110.159','35.253.61.23','34.30.52.134','34.67.133.93','104.198.177.225','35.202.107.105','66.249.68.193','34.135.98.122','34.71.222.96','95.7.240.153','35.253.40.20','136.115.95.158','40.77.167.26','34.27.99.191','192.177.144.201','136.114.7.39','85.208.96.201','34.123.129.208','34.66.127.248','136.116.59.242','40.77.167.63','34.10.108.251','85.208.98.55','34.59.220.183','136.113.248.41','35.239.86.222','188.72.10.106','34.136.179.114','35.255.139.26','35.226.87.141','34.29.229.26','81.246.152.114','34.63.146.186','85.208.98.59','152.163.217.210','68.231.157.227','34.66.90.28','34.173.138.43','136.115.16.60','132.255.81.143','136.111.70.61','34.71.243.182','185.191.171.9','34.134.224.139','34.27.103.20','35.193.156.72','35.202.223.123','136.64.154.238','34.133.64.91','34.133.150.125','104.197.166.106','209.227.22.1','185.191.171.5','34.136.104.39','35.239.226.56','35.222.247.211','35.202.11.48','35.254.208.237','187.45.56.171','176.28.203.79','85.208.98.57','34.171.114.96','35.193.15.59','136.65.206.196','209.227.70.114','35.254.231.19','34.28.30.77','34.9.180.63','35.192.131.166','136.64.93.95','34.10.194.123','34.60.121.79','85.208.96.211','34.59.68.27','216.73.217.83','34.69.172.88','34.31.12.118','151.245.101.228','34.10.84.36','34.172.220.235','35.184.81.141','34.56.146.15','34.31.187.131','35.222.110.111','34.44.249.127','85.208.98.58','35.254.195.237','136.119.145.242','40.77.167.55','136.65.57.107','35.232.21.128','104.154.189.181','34.9.131.229','34.55.227.40','136.112.169.254','35.226.113.131','34.132.16.45','34.29.77.190','34.27.5.65','34.10.254.204','34.135.47.220','35.225.72.94') )
0.000231 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '3933'
0.000174 - SELECT * FROM bb_online WHERE (online_topic = '3933' AND online_uid <> '0')
0.000550 - SELECT * FROM `users` WHERE uid IN (1315,1,2982,5,419,2529,3050,21,2152,841,1779)
0.000295 - SELECT * FROM bb_online WHERE online_uid IN (1315,1,2982,5,419,2529,3050,21,2152,841,1779)
0.000052 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000048 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 8350 AND rank_max >= 8350 AND rank_special = 0
0.000058 - SELECT groupid FROM groups_users_link WHERE uid=1
0.000032 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 7
0.000096 - SELECT groupid FROM groups_users_link WHERE uid=2982
0.000047 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000036 - SELECT groupid FROM groups_users_link WHERE uid=5
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=419
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=2529
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 276 AND rank_max >= 276 AND rank_special = 0
0.000088 - SELECT groupid FROM groups_users_link WHERE uid=3050
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1410 AND rank_max >= 1410 AND rank_special = 0
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=2152
0.000047 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
0.000105 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000029 - SELECT post_id FROM bb_posts WHERE topic_id = 3933 AND pid = 0
Total: 65
Usage de la mémoire: 10229008 bytes
XOOPS output init a mis 0.099 seconde(s) pour charger
