103 Personne(s) en ligne (101 Personne(s) connectée(s) sur Forum)
Invité(s): 103
Fait toi aider.Et fait l'eux.
Kew-Kedew a écrit:
De Saumur 49 Maine et Loire
Post(s): 470
Mégane Coupé Ph2 1.6 16V RSI
du pédalier
sinon voila quelle que photos
De Nantes (44)
Post(s): 1123
Arff la jante a bien plié :-o
un becquet?
mikl68 a écrit:
un becquet?
sa je les dejas
Post(s): 1386
Post(s): 1175
Ah oui #censuré#!
Post(s): 1175
Post(s): 1175
j'espere bien pas cartonné
0.000115 - SET NAMES 'utf8'
0.000162 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.000955 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'c1525d84bc9a436b2b2731e6370b3ee5'
0.000189 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000566 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000199 - SELECT * FROM bb_topics WHERE topic_id=11524
0.000261 - SELECT * FROM bb_forums WHERE forum_id = 23
0.000385 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000237 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 11524
0.000084 - SELECT * FROM bb_topics WHERE topic_id=11524
0.000029 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=11524 AND approved = 1
0.003011 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=11524 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 330, 30
0.001226 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =11524
0.000043 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000330 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.001391 - UPDATE online SET online_updated=1777602439, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.000224 - SELECT * FROM online
0.000069 - -300
0.001379 - DELETE FROM online WHERE online_updated < 1777602139
0.000255 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.000597 - UPDATE online SET online_updated=1777602439, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.000169 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.001365 - UPDATE bb_online SET online_updated= '1777602439', online_forum = '23', online_topic = '11524' WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.001037 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('169.224.14.120','198.244.226.72','85.208.96.206','66.249.66.74','198.244.242.158','51.195.183.215','198.244.226.236','198.244.242.15','51.195.183.15','185.191.171.14','66.249.66.196','66.249.66.68','66.249.66.70','66.249.66.69','51.195.183.77','85.208.96.201','198.244.168.182','51.195.183.133','51.89.129.153','198.244.226.225','185.191.171.3','51.195.244.248','51.89.129.195','66.249.66.34','198.244.242.134','85.208.96.210','51.195.215.188','185.191.171.1','198.244.183.34','51.195.215.86','198.244.168.23','198.244.242.131','51.195.244.101','66.249.66.194','54.38.147.169','51.195.244.133','157.55.39.58','198.244.242.174','198.244.168.18','198.244.226.179','157.55.39.192','54.38.147.55','66.249.66.33','66.249.66.165','66.249.66.72','51.89.129.9','185.191.171.18','198.244.226.80','85.208.96.197','198.244.168.169','66.249.66.6','51.195.215.224','185.191.171.2','51.195.244.71','185.191.171.12','198.244.226.2','51.195.183.73','198.244.226.24','66.249.66.166','198.244.242.232','66.249.66.193','54.38.147.166','198.244.183.66','51.195.215.228','198.244.242.159','66.249.66.192','198.244.242.205','66.249.66.39','51.89.129.204','185.191.171.13','66.249.66.5','51.195.244.1','66.249.66.71','198.244.242.172','51.195.244.65','198.244.183.35','54.38.147.24','198.244.168.186','198.244.183.230','66.249.66.9','51.89.129.147','198.244.226.105','51.195.244.215','51.195.215.0','66.249.66.37','51.195.244.202','51.195.183.42','51.195.183.124','216.73.217.23','85.208.96.212','66.249.66.73','54.38.147.177','198.244.226.209','185.191.171.17','54.38.147.241','198.244.240.22','85.208.96.208','85.208.96.203','185.191.171.8','198.244.226.126','51.89.129.180') )
0.000150 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '11524'
0.000225 - SELECT * FROM bb_online WHERE (online_topic = '11524' AND online_uid <> '0')
0.000461 - SELECT * FROM `users` WHERE uid IN (4282,3711,4151,4050,1779,3663,3841,1129,2683,3784,888)
0.000792 - SELECT * FROM bb_online WHERE online_uid IN (4282,3711,4151,4050,1779,3663,3841,1129,2683,3784,888)
0.000036 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000054 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000043 - SELECT groupid FROM groups_users_link WHERE uid=4151
0.000030 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000029 - SELECT groupid FROM groups_users_link WHERE uid=3663
0.000029 - SELECT groupid FROM groups_users_link WHERE uid=3841
0.000034 - SELECT groupid FROM groups_users_link WHERE uid=1129
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1386 AND rank_max >= 1386 AND rank_special = 0
0.000032 - SELECT groupid FROM groups_users_link WHERE uid=2683
0.000028 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=888
0.000075 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000028 - SELECT post_id FROM bb_posts WHERE topic_id = 11524 AND pid = 0
Usage de la mémoire: 10237952 bytes
XOOPS a mis 0.343 seconde(s) pour charger
XOOPS Boot a mis 0.054 seconde(s) pour charger
XOOPS output init a mis 0.090 seconde(s) pour charger
Module display a mis 0.111 seconde(s) pour charger
