285 Personne(s) en ligne (240 Personne(s) connectée(s) sur Forum)
Invité(s): 285
Petite précision decrantage 1.6e
De savoie
Post(s): 183
Salut, je veux decranter mon auto moi aussi , j'ai un 1.6 et les trains arrière son différents des cab et 2.0l, je voulai savoir si il y a des particularité à savoir? Sachant que la méthode reste identique !
Merci à vous.
Contribution le : 27/06/2017 11:37
Re: Petite précision decrantage 1.6e
salut,
Exactement pareil , pas de soucis de ce coté
Contribution le : 28/06/2017 07:05
De savoie
Post(s): 183
Nikel merci
Contribution le : 28/06/2017 07:35
0.000134 - SET NAMES 'utf8'
0.000220 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '1a1d44e8248e38b8a2439ee631f69dbe'
0.000029 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000218 - SELECT * FROM bb_topics WHERE topic_id=20698
0.000086 - SELECT * FROM bb_forums WHERE forum_id = 10
0.000031 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '10' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000250 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20698
0.000107 - SELECT * FROM bb_topics WHERE topic_id=20698
0.000230 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20698 AND approved = 1
0.000457 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20698 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000306 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20698
0.000098 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000096 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000154 - SELECT * FROM bb_forums ORDER BY forum_order
0.000122 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000262 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.171'
0.000726 - UPDATE online SET online_updated=1792643758, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.171'
0.000535 - SELECT * FROM online
0.000332 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.171'
0.000307 - UPDATE online SET online_updated=1792643758, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.171'
0.000154 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.171'
0.000994 - UPDATE bb_online SET online_updated= '1792643758', online_forum = '10', online_topic = '20698' WHERE online_uid = 0 AND online_ip='216.73.216.171'
0.002335 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('139.47.123.156','43.173.181.237','43.173.179.117','150.107.106.18','198.163.195.34','31.132.55.56','109.156.65.84','100.4.77.55','103.190.225.158','31.171.50.160','94.254.233.94','52.167.144.140','90.107.192.143','140.141.156.235','212.47.150.183','82.140.138.239','82.140.143.53','40.77.167.38','43.173.176.161','145.255.79.229','99.66.253.16','207.204.64.42','149.232.131.54','82.140.138.235','43.172.194.35','43.173.180.21','41.66.25.27','187.189.36.164','40.77.167.123','124.243.184.69','97.170.114.113','207.49.32.180','201.2.190.210','103.252.200.66','92.211.27.76','74.7.241.29','72.63.126.161','110.44.103.217','197.55.73.85','76.33.242.196','201.137.228.68','178.88.56.66','186.237.177.102','45.38.238.60','137.101.140.128','104.244.225.115','94.62.220.74','93.175.47.117','43.172.195.207','43.172.195.131','78.137.205.203','81.34.231.72','189.175.222.241','104.244.225.129','216.73.216.171','43.173.173.200','103.134.226.155','72.63.127.42','138.84.63.47','82.140.143.47','172.59.218.148','209.166.27.175','72.63.1.80','153.79.114.226','192.141.100.95','38.183.48.77','121.200.7.90','197.95.69.175','72.63.127.0','149.19.164.36','172.83.130.101','76.148.107.102','43.172.196.68','185.191.171.10','196.250.215.215','177.241.162.134','190.7.243.152','153.79.114.100','37.109.169.145','31.51.224.79','23.230.234.204','23.27.31.230','185.169.100.130','189.90.29.57','69.91.188.156','180.148.10.38','64.105.213.15','197.38.177.164','48.47.33.62','189.217.207.193','31.126.128.64','104.62.52.63','90.240.78.93','82.23.228.236','84.46.177.131','102.184.227.20','82.215.108.63','82.140.170.94','191.182.104.91','176.144.2.134','128.79.29.199','151.82.233.76','57.138.130.171','38.137.47.95','64.57.129.108','80.0.87.211','62.192.107.188','50.117.49.173','91.100.55.73','200.220.167.187','113.169.60.75','190.6.9.170','75.189.52.249','181.95.57.73','213.94.60.168','72.63.189.137','186.208.240.176','93.47.126.67','95.144.151.87','187.45.117.92','177.74.239.74','181.45.132.18','169.224.3.249','187.191.49.253','191.11.37.209','168.228.143.159','43.173.182.94','191.5.39.205','85.208.96.201','43.173.177.46','43.172.194.171','67.9.128.151','102.66.181.193','179.15.100.206','189.37.68.73','45.164.77.158','90.68.202.20','223.24.209.111','141.226.93.253','63.143.100.87','185.254.150.63','187.40.208.215','75.88.80.128','72.63.189.235','51.235.51.61','181.225.158.205','48.47.11.82','49.36.185.214','38.25.80.5','190.138.138.175','48.47.9.188','85.208.96.194','154.79.251.210','187.189.17.197','103.179.214.54','201.158.41.181','181.115.172.108','31.98.28.141','43.172.197.198','72.63.2.211','43.173.182.198','80.86.229.5','191.240.209.68','116.204.140.29','201.202.13.100','153.79.112.54','43.173.175.242','188.70.47.231','85.208.96.200','144.48.226.70','68.96.54.127','85.246.12.215','143.105.245.140','186.220.84.222','5.228.112.134','177.249.163.137','2.57.97.8','213.230.78.175','49.37.159.170','139.64.180.65','186.225.227.65','43.173.173.237','172.59.85.60','45.190.34.33','88.162.161.134','51.36.232.29','5.148.66.210','23.230.136.79','108.72.16.99','47.231.4.15','187.84.155.206','86.120.190.7','48.47.32.142','72.63.126.240','92.54.116.56','170.100.130.216','38.159.163.247','107.216.112.25','43.173.175.225','67.213.148.230','117.201.237.198','31.132.55.95','185.191.171.13','23.230.234.110','41.251.153.145','190.52.102.187','41.235.160.61','98.253.48.185','185.13.107.231','183.80.217.7','31.98.1.228','171.250.159.199','172.121.37.97','31.98.2.115','196.75.78.191','139.47.27.140','79.117.192.136','40.77.167.151','104.244.227.201','213.22.157.53','82.140.170.18','82.140.143.151','5.29.13.205','72.63.188.99','174.81.90.76','185.58.219.5','189.214.156.175','48.47.31.11','185.191.171.9','191.95.148.251','171.229.77.203','167.249.121.235','79.116.209.215','45.234.214.121','72.63.188.236','125.162.87.219','138.16.230.168','170.100.129.143','43.173.179.110','85.208.96.208') )
0.000218 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20698'
0.000124 - SELECT * FROM bb_online WHERE (online_topic = '20698' AND online_uid <> '0')
0.000275 - SELECT * FROM `users` WHERE uid IN (26563,4383)
0.000118 - SELECT * FROM bb_online WHERE online_uid IN (26563,4383)
0.000069 - SELECT groupid FROM groups_users_link WHERE uid=26563
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 183 AND rank_max >= 183 AND rank_special = 0
0.000096 - SELECT groupid FROM groups_users_link WHERE uid=4383
0.000053 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 2891 AND rank_max >= 2891 AND rank_special = 0
0.000337 - SELECT post_id FROM bb_posts WHERE topic_id = 20698 AND pid = 0
Total: 48
Usage de la mémoire: 8170000 bytes
XOOPS a mis 0.117 seconde(s) pour charger
