80 Personne(s) en ligne (57 Personne(s) connectée(s) sur Forum)
Invité(s): 80
Pignon moteur capote
Post(s): 28
Bonjour je suis un peu embêter je recherche un pignon pour moteur hydraulique de capote sur le tutoriel il dit d aller chez renault mais renault me dit que sa ne se fait plus du coup ou puis je en trouver un ou comment réparée merci d avance
Contribution le : 30/04/2018 08:07
Re: Pignon moteur capote
Post(s): 111
Contribution le : 30/04/2018 08:17
Post(s): 28
Contribution le : 30/04/2018 08:24
0.000159 - SET NAMES 'utf8'
0.001021 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '2642e663a0c0e38a0b456acaf603c2a6'
0.000118 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.001650 - SELECT * FROM bb_topics WHERE topic_id=20949
0.001805 - SELECT * FROM bb_forums WHERE forum_id = 11
0.000065 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '11' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000231 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20949
0.000037 - SELECT * FROM bb_topics WHERE topic_id=20949
0.000186 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20949 AND approved = 1
0.000383 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20949 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000509 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20949
0.000324 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001014 - UPDATE online SET online_updated=1793905362, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000415 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000116 - UPDATE online SET online_updated=1793905362, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000137 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000937 - UPDATE bb_online SET online_updated= '1793905362', online_forum = '11', online_topic = '20949' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000203 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000623 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('193.56.20.216','185.191.171.8','82.174.26.146','87.58.192.51','85.106.157.136','190.5.37.222','66.249.70.193','185.191.171.15','85.208.96.209','85.208.96.204','102.211.11.219','202.141.53.37','144.76.23.213','31.105.111.224','66.249.70.192','66.249.84.39','168.222.30.35','146.19.78.235','82.24.234.194','202.46.62.2','185.191.171.11','202.46.62.1','185.190.132.139','185.191.171.14','88.203.120.76','64.49.39.109','37.114.150.33','82.22.239.31','177.131.77.132','5.183.252.197','103.115.158.82','179.0.127.5','212.119.40.43','85.208.96.207','185.61.223.30','136.169.155.183','1.55.95.221','84.50.221.175','85.147.110.244','40.77.167.7','185.191.171.1','187.0.233.82','66.249.64.7','31.105.113.78','92.130.80.145','186.19.123.106','5.91.183.159','85.208.96.211','109.177.246.61','140.235.0.242','216.73.216.84','85.208.96.212','192.101.65.230','177.92.50.67','202.46.62.14','46.185.191.197','170.84.9.84') )
0.000162 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20949'
0.000210 - SELECT * FROM bb_online WHERE (online_topic = '20949' AND online_uid <> '0')
0.000088 - SELECT * FROM `users` WHERE uid IN (27447,27059)
0.000142 - SELECT * FROM bb_online WHERE online_uid IN (27447,27059)
0.000070 - SELECT groupid FROM groups_users_link WHERE uid=27447
0.000029 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 28 AND rank_max >= 28 AND rank_special = 0
0.000040 - SELECT groupid FROM groups_users_link WHERE uid=27059
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 111 AND rank_max >= 111 AND rank_special = 0
0.000236 - SELECT post_id FROM bb_posts WHERE topic_id = 20949 AND pid = 0
Total: 48
Usage de la mémoire: 8164416 bytes
XOOPS a mis 0.144 seconde(s) pour charger
