182 Personne(s) en ligne (132 Personne(s) connectée(s) sur Forum)
Invité(s): 182
oula ca magouille par ici lol
Ca me va !
mp fait
De Essonne (sous ma voiture)
Post(s): 798
F7R 714 - MONTE CARLO
Avant
Apres
- Pas la même coque (phase 2)
rétro ph2 effectivement.
Exactement la même chose.
Sinon du nouveau !
ho de la belle piece,
aile +1 pouce ?
Top ça
De Nogaro (32)
Post(s): 75
ShInGiN a écrit:
Top ça
0.000125 - SET NAMES 'utf8'
0.000976 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '92f9988a1b564930211be7569420d56d'
0.000370 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 365087
0.000046 - SELECT * FROM bb_forums WHERE forum_id = 23
0.000055 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '23' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000302 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 5629
0.000108 - SELECT * FROM bb_topics WHERE topic_id=5629
0.000027 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1
0.006686 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1 AND post_id < 365087
0.015552 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=5629 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 2100, 30
0.000377 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =5629
0.000117 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000110 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000151 - SELECT * FROM groups
0.000726 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000146 - UPDATE online SET online_updated=1792762462, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000270 - SELECT * FROM online
0.000377 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000271 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000504 - UPDATE online SET online_updated=1792762462, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000288 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000403 - UPDATE bb_online SET online_updated= '1792762462', online_forum = '23', online_topic = '5629' WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.001131 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('179.221.201.197','189.104.204.135','189.104.34.30','103.140.83.201','41.142.69.114','85.208.96.211','64.52.27.247','37.113.209.227','190.56.195.221','212.106.80.136','85.208.96.195','185.191.171.9','195.40.169.56','189.81.5.123','45.183.151.245','42.116.184.87','189.104.34.135','85.208.96.209','189.104.67.10','79.117.225.145','172.120.139.40','49.48.242.12','160.119.49.32','176.240.128.40','38.51.26.19','88.168.152.20','104.164.118.159','71.12.172.178','156.208.194.173','72.63.19.235','173.188.49.108','101.128.98.153','31.105.102.181','90.46.8.156','103.212.116.90','85.208.98.58','185.191.171.7','104.164.251.98','185.191.171.17','104.165.74.151','172.121.254.76','104.165.161.21','40.77.167.55','207.32.139.18','104.252.94.211','176.28.165.150','104.165.161.160','181.127.151.174','189.104.35.238','189.81.70.87','189.81.2.90','172.120.249.68','176.20.211.78','103.150.18.169','216.73.217.110','64.52.26.222','92.96.146.137','101.56.186.126','189.81.4.124','83.61.204.69','172.121.37.18','191.5.36.8','104.165.161.43','189.104.241.249','176.20.210.99','72.63.72.87','94.98.186.58','62.217.154.71','171.250.163.225','85.208.98.55','87.216.102.1','185.191.171.16','185.191.171.11','81.88.147.193','90.162.229.197','174.140.218.174','154.180.186.76','188.157.28.113','103.109.213.25','77.222.98.111','72.63.71.142','185.191.171.18','104.252.7.88','189.81.5.228','185.191.171.3','181.79.147.171','66.249.69.67','14.162.51.113','72.63.71.214','172.121.43.161','86.23.218.22','216.114.241.208','87.232.156.181','185.191.171.12','116.98.247.247','93.178.6.48','104.165.187.33','72.63.72.133','84.37.118.212','104.165.250.37','188.54.46.54','212.112.111.111','157.100.186.97','40.77.167.50','86.138.72.193','181.189.77.66','189.81.3.249','186.14.1.66','85.208.96.198','41.188.116.135','153.243.115.137','85.208.98.57','172.121.254.97','216.234.215.59','88.157.3.132','189.81.235.144','93.44.194.191','188.236.57.182','178.89.16.176','189.81.4.5','185.191.171.13','85.208.96.212','196.238.121.27','213.246.253.30','85.208.96.206','186.151.100.41','72.27.5.63','101.57.47.120','179.191.34.7','192.177.122.6','172.121.255.191','189.81.71.5') )
0.000221 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '5629'
0.000154 - SELECT * FROM bb_online WHERE (online_topic = '5629' AND online_uid <> '0')
0.000408 - SELECT * FROM `users` WHERE uid IN (1611,4383,21,10994,3711,1587,5,841,13128)
0.000251 - SELECT * FROM bb_online WHERE online_uid IN (1611,4383,21,10994,3711,1587,5,841,13128)
0.000034 - SELECT groupid FROM groups_users_link WHERE uid=1611
0.000033 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1547 AND rank_max >= 1547 AND rank_special = 0
0.000061 - SELECT groupid FROM groups_users_link WHERE uid=4383
0.000053 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000126 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000132 - SELECT groupid FROM groups_users_link WHERE uid=10994
0.006996 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000084 - SELECT groupid FROM groups_users_link WHERE uid=1587
0.000712 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
0.000530 - SELECT groupid FROM groups_users_link WHERE uid=5
0.000042 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.018012 - SELECT groupid FROM groups_users_link WHERE uid=841
0.003481 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
0.000227 - SELECT groupid FROM groups_users_link WHERE uid=13128
0.000191 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 75 AND rank_max >= 75 AND rank_special = 0
0.000156 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000031 - SELECT post_id FROM bb_posts WHERE topic_id = 5629 AND pid = 0
Total: 63
Usage de la mémoire: 10077480 bytes
XOOPS a mis 0.186 seconde(s) pour charger
Module init a mis 0.037 seconde(s) pour charger
XOOPS output init a mis 0.028 seconde(s) pour charger
Module display a mis 0.092 seconde(s) pour charger
Page rendering a mis 0.013 seconde(s) pour charger
