163 Personne(s) en ligne (119 Personne(s) connectée(s) sur Forum)
Invité(s): 163
oula ca magouille par ici lol
Ca me va !
mp fait
De Essonne (sous ma voiture)
Post(s): 798
F7R 714 - MONTE CARLO
Avant
Apres
- Pas la même coque (phase 2)
rétro ph2 effectivement.
Exactement la même chose.
Sinon du nouveau !
ho de la belle piece,
aile +1 pouce ?
Top ça
De Nogaro (32)
Post(s): 75
ShInGiN a écrit:
Top ça
0.000131 - SET NAMES 'utf8'
0.003234 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.000772 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '7d6e1c4679b8c45eaa59a653c151ec21'
0.000305 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 365785
0.000249 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 5629
0.000156 - SELECT * FROM bb_topics WHERE topic_id=5629
0.000039 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1
0.006624 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1 AND post_id < 365785
0.000098 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=5629 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 2100, 30
0.000603 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =5629
0.000652 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000060 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000153 - DELETE FROM online WHERE online_updated < 1792758820
0.000201 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000226 - UPDATE online SET online_updated=1792759120, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000292 - SELECT * FROM online
0.000159 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000213 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000348 - UPDATE online SET online_updated=1792759120, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000175 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000237 - UPDATE bb_online SET online_updated= '1792759120', online_forum = '23', online_topic = '5629' WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.001056 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('189.81.5.82','85.208.96.209','185.191.171.6','185.237.102.133','104.252.116.44','172.120.139.3','181.91.86.146','64.52.25.22','64.52.27.192','69.17.19.130','185.191.171.1','160.250.241.133','189.104.240.196','74.7.241.29','85.208.96.207','189.81.2.74','64.52.26.202','88.138.77.144','132.196.86.74','104.164.250.34','49.151.234.121','85.208.96.208','179.37.110.37','161.0.2.234','45.7.25.31','220.181.108.176','195.40.169.17','104.252.7.237','185.191.171.16','185.224.112.66','79.52.77.128','136.158.49.12','176.20.211.220','189.81.192.123','103.77.191.152','185.191.171.4','88.99.95.199','85.208.96.194','92.57.18.1','177.223.246.102','45.38.10.224','23.108.72.252','85.208.96.212','189.81.192.93','85.208.96.210','132.196.86.136','170.79.222.168','185.191.171.10','85.250.100.153','181.214.168.215','185.191.171.9','176.151.227.49','181.53.96.28','71.38.225.148','185.191.171.2','52.167.144.136','104.252.229.139','186.216.60.200','104.252.38.120','105.155.44.39','78.182.149.142','189.104.35.39','169.238.86.253','181.121.62.28','192.7.58.147','172.121.254.77','49.43.240.67','181.43.34.42','76.125.227.126','185.191.171.7','172.121.38.162','5.167.158.202','191.102.139.182','104.252.209.50','189.104.35.241','85.208.96.199','216.73.217.110','189.81.192.52','40.77.167.159','192.145.68.121','189.81.71.49','104.253.10.236','217.164.151.122','172.252.120.207','94.128.153.176','172.121.37.220','172.121.255.235','185.191.171.17','104.252.209.176','87.117.189.58','172.120.139.24','179.178.12.24','181.175.92.139','185.191.171.13','189.81.3.122','223.233.86.185','85.208.96.196','85.208.96.195','179.189.34.45','172.121.37.153','207.32.129.80','189.46.126.124','144.124.196.60','85.208.96.193','45.165.44.154','189.81.5.173','167.148.206.124','104.253.160.248','45.176.232.137','172.121.254.100','191.95.144.60','104.253.129.219','176.20.211.119','85.208.96.211','64.218.113.13','185.191.171.11','93.34.91.248','172.121.11.87','172.121.255.73') )
0.000227 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '5629'
0.000152 - SELECT * FROM bb_online WHERE (online_topic = '5629' AND online_uid <> '0')
0.000072 - SELECT * FROM `users` WHERE uid IN (1611,4383,21,10994,3711,1587,5,841,13128)
0.000212 - SELECT * FROM bb_online WHERE online_uid IN (1611,4383,21,10994,3711,1587,5,841,13128)
0.000047 - SELECT groupid FROM groups_users_link WHERE uid=1611
0.000038 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1547 AND rank_max >= 1547 AND rank_special = 0
0.000048 - SELECT groupid FROM groups_users_link WHERE uid=4383
0.000034 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 2891 AND rank_max >= 2891 AND rank_special = 0
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=10994
0.000034 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 9
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=1587
0.000041 - SELECT groupid FROM groups_users_link WHERE uid=5
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=13128
0.000034 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 75 AND rank_max >= 75 AND rank_special = 0
0.000036 - SELECT post_id FROM bb_posts WHERE topic_id = 5629 AND pid = 0
Usage de la mémoire: 10078656 bytes
XOOPS a mis 0.170 seconde(s) pour charger
