143 Personne(s) en ligne (98 Personne(s) connectée(s) sur Forum)
Invité(s): 143
oula ca magouille par ici lol
Ca me va !
mp fait
De Essonne (sous ma voiture)
Post(s): 798
F7R 714 - MONTE CARLO
Avant
Apres
- Pas la même coque (phase 2)
rétro ph2 effectivement.
Exactement la même chose.
Sinon du nouveau !
ho de la belle piece,
aile +1 pouce ?
Top ça
De Nogaro (32)
Post(s): 75
ShInGiN a écrit:
Top ça
0.000093 - SET NAMES 'utf8'
0.000693 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '143c5afa9f81ce7963b02eaddea18102'
0.000280 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 367548
0.000246 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 5629
0.000128 - SELECT * FROM bb_topics WHERE topic_id=5629
0.001423 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1
0.006948 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1 AND post_id < 367548
0.000122 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=5629 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 2100, 30
0.000301 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =5629
0.000150 - SELECT * FROM bb_forums ORDER BY forum_order
0.000256 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000362 - UPDATE online SET online_updated=1792758877, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000774 - SELECT * FROM online
0.000174 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000274 - UPDATE online SET online_updated=1792758877, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000142 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000329 - UPDATE bb_online SET online_updated= '1792758877', online_forum = '23', online_topic = '5629' WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000934 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('185.191.171.15','85.208.96.209','102.217.85.96','181.91.86.146','64.52.25.22','64.52.27.192','185.191.171.14','160.179.234.124','47.211.161.216','160.250.241.133','189.104.240.196','74.7.241.29','207.32.129.218','172.182.207.83','64.52.26.202','88.138.77.144','104.165.187.245','207.32.129.198','109.236.40.15','85.208.96.202','191.102.139.42','189.81.71.52','189.81.2.147','87.232.153.99','95.23.116.220','190.183.248.207','185.191.171.16','85.208.96.203','104.252.229.73','176.20.211.220','172.121.254.76','88.99.95.199','85.208.96.194','92.57.18.1','177.223.246.102','45.38.10.224','23.108.72.252','85.208.96.212','207.32.135.179','207.32.135.21','132.196.86.136','185.191.171.4','104.252.229.196','104.253.135.26','181.214.168.215','177.220.182.15','181.53.96.28','168.205.181.252','104.164.250.28','52.167.144.136','173.49.214.74','181.214.168.52','49.149.98.220','85.208.96.206','181.42.137.42','85.208.96.207','40.77.167.152','185.191.171.6','104.253.160.207','85.208.96.197','172.252.120.242','185.191.171.7','172.121.38.162','5.167.158.202','176.159.202.58','104.164.251.242','200.153.214.140','85.208.96.199','216.73.217.110','185.191.171.2','189.81.3.128','188.163.101.32','37.106.6.231','87.232.154.217','105.235.139.174','195.40.125.242','186.216.30.173','172.120.139.118','104.253.160.156','41.143.47.80','172.121.37.250','177.223.23.110','189.81.3.246','179.189.34.45','172.121.37.153','189.81.4.239','174.140.218.174','104.164.101.153','86.161.25.231','196.189.121.60','104.164.118.133','99.169.55.161','62.183.17.3','185.191.171.11','95.190.5.91','195.40.169.139','93.34.91.248','172.121.11.87') )
0.000206 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '5629'
0.000286 - SELECT * FROM bb_online WHERE (online_topic = '5629' AND online_uid <> '0')
0.000060 - SELECT * FROM `users` WHERE uid IN (1611,4383,21,10994,3711,1587,5,841,13128)
0.000175 - SELECT * FROM bb_online WHERE online_uid IN (1611,4383,21,10994,3711,1587,5,841,13128)
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=1611
0.000032 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1547 AND rank_max >= 1547 AND rank_special = 0
0.000073 - SELECT groupid FROM groups_users_link WHERE uid=4383
0.000138 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 2891 AND rank_max >= 2891 AND rank_special = 0
0.000048 - SELECT groupid FROM groups_users_link WHERE uid=10994
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000024 - SELECT groupid FROM groups_users_link WHERE uid=5
0.000030 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000063 - SELECT groupid FROM groups_users_link WHERE uid=13128
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 75 AND rank_max >= 75 AND rank_special = 0
0.000119 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000025 - SELECT post_id FROM bb_posts WHERE topic_id = 5629 AND pid = 0
Total: 63
Usage de la mémoire: 10078320 bytes
