88 Personne(s) en ligne (60 Personne(s) connectée(s) sur Forum)
Invité(s): 88
uch
De 07
Post(s): 296
salut
je veut démonter un uch de scenic de 1999 c'est chaud comment on fait?Des astuces?
Contribution le : 10/06/2017 16:46
Re: uch
Il y a qu'une vis de mémoire, après faut juste déclipser toutes les cosses une a une.
Contribution le : 12/06/2017 09:12
Re: uch
De 07
Post(s): 296
ok merci je démonte sa mercredi je ferrais des photo et je lancerais dans un tuto pour voire si sa intéresse.
Contribution le : 12/06/2017 11:19
0.000139 - SET NAMES 'utf8'
0.000120 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001394 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '0d099c2b11f3b91cc53a429bb41110fe'
0.000361 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 376843
0.000085 - SELECT * FROM bb_forums WHERE forum_id = 3
0.000066 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '3' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000246 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20669
0.000337 - SELECT * FROM bb_topics WHERE topic_id=20669
0.000270 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20669 AND approved = 1
0.000198 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20669 AND approved = 1 AND post_id < 376843
0.000268 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20669 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000259 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20669
0.000140 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.049381 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000223 - UPDATE online SET online_updated=1793907332, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000084 - -300
0.000116 - DELETE FROM online WHERE online_updated < 1793907032
0.000162 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001369 - UPDATE online SET online_updated=1793907332, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000426 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000148 - UPDATE bb_online SET online_updated= '1793907332', online_forum = '3', online_topic = '20669' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000197 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000637 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('128.127.120.23','193.203.9.68','168.167.18.189','51.174.15.124','193.104.126.69','206.180.143.95','85.208.96.211','93.170.185.63','185.191.171.19','45.225.91.109','185.191.171.11','45.148.234.27','113.19.183.24','41.50.57.29','157.55.39.205','102.208.120.145','5.183.255.39','179.6.23.166','202.46.61.111','80.217.238.224','66.249.70.192','196.207.235.29','188.212.135.222','85.208.96.203','2.214.61.184','102.223.157.229','40.77.167.24','31.134.2.41','85.208.96.205','143.59.216.8','186.169.63.72','216.73.216.84','90.35.59.72','185.191.171.6','50.117.107.184','185.191.171.12','80.68.109.42','190.61.114.243','185.191.171.2','92.109.217.123','186.179.68.20','62.217.141.166','190.104.106.69','31.134.7.68','188.167.251.243','217.136.89.251','185.191.171.18','217.39.51.218','27.114.151.78','147.235.197.197','178.51.137.190','85.208.96.210','185.191.171.10','216.234.223.110','173.34.128.251','85.117.228.153','74.125.210.196','66.249.70.202','185.191.171.13','185.171.61.64') )
0.000160 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20669'
0.000403 - SELECT * FROM bb_online WHERE (online_topic = '20669' AND online_uid <> '0')
0.000286 - SELECT * FROM `users` WHERE uid IN (9247,21)
0.000123 - SELECT * FROM bb_online WHERE online_uid IN (9247,21)
0.000072 - SELECT groupid FROM groups_users_link WHERE uid=9247
0.000027 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 296 AND rank_max >= 296 AND rank_special = 0
0.000074 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000179 - SELECT post_id FROM bb_posts WHERE topic_id = 20669 AND pid = 0
Usage de la mémoire: 8179160 bytes
XOOPS a mis 0.229 seconde(s) pour charger
XOOPS Boot a mis 0.058 seconde(s) pour charger
XOOPS output init a mis 0.088 seconde(s) pour charger
