186 Personne(s) en ligne (145 Personne(s) connectée(s) sur Forum)
Invité(s): 186
uch
De 07
Post(s): 296
salut
je veut démonter un uch de scenic de 1999 c'est chaud comment on fait?Des astuces?
Contribution le : 10/06/2017 16:46
Re: uch
Il y a qu'une vis de mémoire, après faut juste déclipser toutes les cosses une a une.
Contribution le : 12/06/2017 09:12
Re: uch
De 07
Post(s): 296
ok merci je démonte sa mercredi je ferrais des photo et je lancerais dans un tuto pour voire si sa intéresse.
Contribution le : 12/06/2017 11:19
0.000172 - SET NAMES 'utf8'
0.001462 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '8ca275f3c15a3541eb43cc41d46ca957'
0.000501 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 376849
0.000061 - SELECT * FROM bb_forums WHERE forum_id = 3
0.000055 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000042 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '3' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000294 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20669
0.000725 - SELECT * FROM bb_topics WHERE topic_id=20669
0.000188 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20669 AND approved = 1
0.000333 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20669 AND approved = 1 AND post_id < 376849
0.000415 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20669 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000484 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20669
0.000101 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000125 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000075 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000107 - SELECT * FROM groups
0.000516 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.001017 - UPDATE online SET online_updated=1789916645, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000317 - SELECT * FROM online
0.000755 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000909 - UPDATE online SET online_updated=1789916645, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000217 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000892 - UPDATE bb_online SET online_updated= '1789916645', online_forum = '3', online_topic = '20669' WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000285 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001428 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('104.197.166.106','34.9.203.105','104.198.16.217','34.134.246.204','98.172.237.108','212.58.114.249','34.44.229.100','35.226.113.131','35.188.85.51','34.30.233.192','34.172.78.224','34.55.227.40','34.172.174.93','136.65.73.35','35.255.220.188','34.44.200.48','34.71.222.96','146.148.110.159','34.123.129.208','66.249.68.193','179.125.143.29','136.115.148.7','34.29.246.143','34.42.190.171','34.66.2.52','34.66.127.248','66.249.79.5','34.60.251.45','34.67.133.93','35.225.72.94','172.10.252.194','103.191.131.154','158.140.203.96','35.226.190.245','35.254.208.237','180.94.2.248','34.30.230.50','35.222.247.211','34.71.243.182','35.238.73.253','34.31.12.118','136.112.169.254','34.55.56.100','34.55.37.33','35.192.131.166','35.255.64.216','34.56.146.15','34.171.232.236','35.192.48.46','34.136.111.60','188.52.210.38','52.167.144.208','35.255.247.90','85.208.96.207','34.170.20.48','136.114.251.171','35.192.61.174','185.191.171.16','136.111.73.51','104.165.249.0','177.81.75.93','136.115.16.60','66.191.159.165','35.239.226.56','34.29.229.26','34.59.68.27','220.181.108.92','34.41.18.53','35.232.208.144','181.14.176.215','35.222.47.18','35.188.212.31','35.254.195.237','154.51.177.123','136.65.144.175','34.45.53.200','181.51.32.163','34.61.77.59','34.31.187.131','35.193.15.59','34.136.50.121','136.115.0.150','103.161.71.5','136.112.32.154','34.122.252.130','202.22.198.75','104.198.47.65','35.226.83.174','35.193.255.230','34.10.194.123','103.88.142.55','85.86.57.74','37.55.130.233','104.155.129.90','185.191.171.12','34.31.207.226','209.227.22.69','38.172.170.185','34.172.184.174','136.114.190.91','185.63.102.195','34.60.121.79','185.191.171.9','34.67.161.204','34.28.30.77','35.254.55.111','144.225.99.39','136.119.214.88','104.252.166.35','45.124.171.169','35.202.223.123','136.65.65.243','185.191.171.7','187.56.254.68','35.184.81.141','40.77.167.130','136.119.145.242','34.44.249.127','136.115.98.185','34.9.180.63','34.172.179.139','136.115.95.158','136.65.57.107','34.173.64.78','34.59.220.183','136.112.177.219','35.254.25.136','216.73.217.83','34.132.16.45','34.132.30.84','85.208.96.197','34.28.60.93','5.29.13.251','34.67.245.67','185.191.171.8','34.63.146.186','35.193.156.72','34.61.148.235','35.254.235.190','34.27.103.20','66.249.68.194','34.10.108.251','35.226.87.141','34.57.115.209','95.93.152.33') )
0.000190 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20669'
0.000235 - SELECT * FROM bb_online WHERE (online_topic = '20669' AND online_uid <> '0')
0.000097 - SELECT * FROM `users` WHERE uid IN (9247,21)
0.000286 - SELECT * FROM bb_online WHERE online_uid IN (9247,21)
0.000067 - SELECT groupid FROM groups_users_link WHERE uid=9247
0.000028 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 296 AND rank_max >= 296 AND rank_special = 0
0.000078 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000099 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000397 - SELECT post_id FROM bb_posts WHERE topic_id = 20669 AND pid = 0
Total: 49
Usage de la mémoire: 8187936 bytes
XOOPS a mis 0.148 seconde(s) pour charger
