120 Personne(s) en ligne (87 Personne(s) connectée(s) sur Forum)
Invité(s): 120
uch
De 07
Post(s): 296
salut
je veut démonter un uch de scenic de 1999 c'est chaud comment on fait?Des astuces?
Contribution le : 10/06/2017 16:46
Re: uch
Il y a qu'une vis de mémoire, après faut juste déclipser toutes les cosses une a une.
Contribution le : 12/06/2017 09:12
Re: uch
De 07
Post(s): 296
ok merci je démonte sa mercredi je ferrais des photo et je lancerais dans un tuto pour voire si sa intéresse.
Contribution le : 12/06/2017 11:19
0.000158 - SET NAMES 'utf8'
0.000212 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001170 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'ba27e2a06c1b0f626b69c738724c921f'
0.000398 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000300 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 376852
0.000060 - SELECT * FROM bb_forums WHERE forum_id = 3
0.000254 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000066 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '3' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000253 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20669
0.000485 - SELECT * FROM bb_topics WHERE topic_id=20669
0.000032 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20669 AND approved = 1
0.000470 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20669 AND approved = 1 AND post_id < 376852
0.000732 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20669 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000935 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20669
0.000090 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000096 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000108 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000536 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000519 - UPDATE online SET online_updated=1793909989, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000746 - SELECT * FROM online
0.000141 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.005470 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000905 - UPDATE online SET online_updated=1793909989, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000171 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.001105 - UPDATE bb_online SET online_updated= '1793909989', online_forum = '3', online_topic = '20669' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000443 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001185 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('202.46.62.35','5.241.139.159','31.134.3.105','213.6.102.191','86.41.130.37','91.127.8.193','86.176.131.23','186.77.206.155','122.8.45.30','41.214.3.214','195.36.204.216','41.60.90.222','41.208.141.74','93.152.80.68','216.147.125.54','165.162.147.132','95.84.66.119','45.80.107.214','185.101.21.206','185.191.171.5','66.249.84.33','46.128.8.6','178.40.240.129','38.51.121.60','79.177.131.91','185.191.171.1','200.149.89.194','31.105.105.36','41.74.138.65','23.230.40.155','85.208.96.212','178.43.244.182','109.242.90.144','157.22.72.59','185.191.171.16','93.152.85.28','176.124.236.241','90.36.61.149','202.46.61.135','202.46.62.32','157.55.39.204','85.208.96.195','109.196.67.205','195.81.191.106','45.66.210.122','92.208.38.143','198.91.152.111','221.153.124.214','155.4.206.246','186.91.18.171','106.73.159.193','90.233.195.169','41.83.45.142','27.79.121.243','212.93.153.39','188.151.133.137','185.191.171.11','109.81.12.155','202.46.61.89','197.146.138.106','87.125.178.27','88.0.91.243','173.33.114.42','190.145.240.183','185.191.171.13','199.201.92.59','51.175.158.185','85.208.96.209','216.73.216.244','66.9.171.28','85.208.96.193','91.82.240.128','85.208.96.196','90.14.5.65','93.117.164.200','201.4.71.213','152.232.247.173','213.232.122.23','85.208.96.206','190.99.23.153','102.38.1.172','155.133.78.47','66.249.70.192','138.84.47.240','134.249.12.43','79.106.215.227','103.181.127.136') )
0.000187 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20669'
0.000718 - SELECT * FROM bb_online WHERE (online_topic = '20669' AND online_uid <> '0')
0.000109 - SELECT * FROM `users` WHERE uid IN (9247,21)
0.000185 - SELECT * FROM bb_online WHERE online_uid IN (9247,21)
0.000176 - SELECT groupid FROM groups_users_link WHERE uid=9247
0.000036 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 296 AND rank_max >= 296 AND rank_special = 0
0.000056 - SELECT groupid FROM groups_users_link WHERE uid=21
0.005463 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000066 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000034 - SELECT post_id FROM bb_posts WHERE topic_id = 20669 AND pid = 0
Total: 49
Usage de la mémoire: 8178216 bytes
