165 Personne(s) en ligne (127 Personne(s) connectée(s) sur Forum)
Invité(s): 165
oula ca magouille par ici lol
Ca me va !
mp fait
De Essonne (sous ma voiture)
Post(s): 798
F7R 714 - MONTE CARLO
Avant
Apres
- Pas la même coque (phase 2)
rétro ph2 effectivement.
Exactement la même chose.
Sinon du nouveau !
ho de la belle piece,
aile +1 pouce ?
Top ça
De Nogaro (32)
Post(s): 75
ShInGiN a écrit:
Top ça
0.000136 - SET NAMES 'utf8'
0.001018 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '333ce65c8fbd9ee24db0732e07abb59b'
0.000323 - SELECT * FROM bb_topics WHERE topic_id=5629
0.000511 - SELECT * FROM bb_forums WHERE forum_id = 23
0.000051 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '23' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000230 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 5629
0.000061 - SELECT * FROM bb_topics WHERE topic_id=5629
0.000030 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1
0.016376 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=5629 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 2100, 30
0.000287 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =5629
0.000103 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000306 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000126 - UPDATE online SET online_updated=1792755689, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000336 - SELECT * FROM online
0.000153 - UPDATE online SET online_updated=1792755689, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000144 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000875 - UPDATE bb_online SET online_updated= '1792755689', online_forum = '23', online_topic = '5629' WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000234 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001155 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('84.37.118.215','208.90.179.206','5.139.232.166','185.191.171.6','45.93.96.33','191.102.139.211','189.104.34.168','41.250.5.57','201.25.175.200','220.181.108.176','72.252.112.164','192.145.68.3','186.152.130.67','185.191.171.10','104.253.130.136','45.38.189.199','74.7.241.29','185.191.171.9','104.164.250.50','104.164.118.34','207.32.139.15','82.22.216.127','196.119.36.232','172.252.5.97','201.25.175.238','172.121.96.161','116.105.138.170','154.192.232.203','181.170.186.81','177.39.124.237','105.78.67.23','72.63.19.74','104.164.118.5','94.131.79.170','85.208.96.200','176.20.211.63','179.125.240.58','192.145.68.165','104.165.187.178','177.68.242.239','172.59.223.36','131.161.45.64','157.51.229.218','88.99.95.199','104.252.229.164','154.80.37.184','188.236.117.110','104.252.38.198','202.51.69.227','189.81.71.9','202.125.68.139','185.191.171.19','192.177.105.3','195.40.169.171','191.102.139.58','189.81.4.86','1.92.217.77','104.253.10.231','191.102.139.47','49.192.184.18','185.191.171.3','121.200.61.150','207.32.153.126','72.63.19.135','85.208.96.203','189.81.71.120','85.208.96.201','172.121.37.135','170.84.181.53','192.177.122.73','185.191.171.15','170.82.148.87','191.102.139.162','138.97.197.49','103.167.172.18','189.81.71.205','139.94.240.136','168.90.62.238','110.93.86.164','172.121.43.33','189.81.3.91','92.124.161.156','153.67.183.113','185.139.138.186','85.208.96.209','85.208.96.196','171.225.209.136','104.252.94.183','85.208.96.206','41.135.193.253','145.82.30.34','49.233.183.197','72.63.72.228','172.121.37.85','43.153.112.202','185.242.58.169','216.73.217.110','185.234.26.228','72.63.249.9','172.252.120.155','69.156.206.228','172.252.127.125','179.0.117.184','141.148.190.9','80.4.22.78','85.208.96.205','177.5.139.188','185.191.171.14','195.40.125.17','192.177.122.189','185.191.171.16','85.208.96.210','105.77.197.124','104.164.251.26','27.123.172.4','103.153.170.113','85.208.96.211','132.196.86.102','179.125.135.36','104.165.161.23','168.222.51.231','212.119.50.206','179.116.79.124','104.252.7.39','103.143.237.44','172.252.120.21','172.120.139.15') )
0.000219 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '5629'
0.000238 - SELECT * FROM bb_online WHERE (online_topic = '5629' AND online_uid <> '0')
0.000488 - SELECT * FROM `users` WHERE uid IN (1611,4383,21,10994,3711,1587,5,841,13128)
0.000233 - SELECT * FROM bb_online WHERE online_uid IN (1611,4383,21,10994,3711,1587,5,841,13128)
0.000058 - SELECT groupid FROM groups_users_link WHERE uid=1611
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=10994
0.000023 - SELECT groupid FROM groups_users_link WHERE uid=5
0.000052 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000065 - SELECT groupid FROM groups_users_link WHERE uid=13128
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 75 AND rank_max >= 75 AND rank_special = 0
0.000111 - SELECT * FROM bb_categories WHERE cat_id = 8
Usage de la mémoire: 10078896 bytes
Module init a mis 0.030 seconde(s) pour charger
