115 Personne(s) en ligne (84 Personne(s) connectée(s) sur Forum)
Invité(s): 115
uch
De 07
Post(s): 296
salut
je veut démonter un uch de scenic de 1999 c'est chaud comment on fait?Des astuces?
Contribution le : 10/06/2017 16:46
Re: uch
Il y a qu'une vis de mémoire, après faut juste déclipser toutes les cosses une a une.
Contribution le : 12/06/2017 09:12
Re: uch
De 07
Post(s): 296
ok merci je démonte sa mercredi je ferrais des photo et je lancerais dans un tuto pour voire si sa intéresse.
Contribution le : 12/06/2017 11:19
0.000067 - SET NAMES 'utf8'
0.001232 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '49d90b6357197e0d1840ba6294a57361'
0.000036 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000194 - SELECT * FROM bb_topics WHERE topic_id=20669
0.000742 - SELECT * FROM bb_forums WHERE forum_id = 3
0.000274 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000098 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000057 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '3' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000224 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20669
0.000024 - SELECT * FROM bb_topics WHERE topic_id=20669
0.000199 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20669 AND approved = 1
0.000661 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20669 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000269 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20669
0.000151 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000060 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000094 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000137 - SELECT * FROM bb_forums ORDER BY forum_order
0.000299 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000434 - UPDATE online SET online_updated=1793906151, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000343 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000145 - UPDATE online SET online_updated=1793906151, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000155 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000275 - UPDATE bb_online SET online_updated= '1793906151', online_forum = '3', online_topic = '20669' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000869 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('62.204.49.250','185.191.171.6','185.77.223.189','86.45.209.138','162.141.97.158','185.195.185.78','188.187.15.75','87.197.92.130','87.56.23.39','109.174.146.87','102.0.31.4','105.113.102.255','85.208.96.197','105.108.219.242','115.76.126.43','155.4.125.107','185.191.171.2','102.253.64.25','37.131.43.187','85.208.96.202','185.191.171.17','80.32.2.178','103.59.38.33','185.135.69.82','66.249.70.202','38.183.115.146','197.234.87.219','202.46.62.61','190.174.110.142','191.23.75.89','186.251.6.179','5.134.86.124','66.249.70.201','168.222.82.41','85.208.96.206','196.238.219.122','195.81.136.135','66.249.70.192','91.132.124.222','31.36.227.51','122.8.46.18','85.208.96.195','195.81.154.173','66.249.70.195','216.73.216.84','46.162.203.26','92.41.50.111','177.115.3.168','24.16.219.183','187.190.11.189','66.249.70.197','66.249.70.193','66.249.64.6','77.207.54.11','185.191.171.10','45.234.16.166','157.22.44.123','93.148.111.30','149.200.77.35','45.67.171.92','83.134.25.230','66.249.70.196','185.201.139.202','68.167.156.165','85.208.96.203','177.131.77.132','185.190.132.139','202.46.61.76','209.212.220.178','195.81.148.7','85.208.96.207','185.191.171.3','62.65.228.98','192.101.65.200','78.181.17.152','103.203.37.35','66.249.70.199','85.208.96.209','196.189.57.103','66.249.64.8','66.249.64.7','190.110.179.61','212.119.47.150','45.147.8.182') )
0.000156 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20669'
0.000244 - SELECT * FROM bb_online WHERE (online_topic = '20669' AND online_uid <> '0')
0.000279 - SELECT * FROM `users` WHERE uid IN (9247,21)
0.000155 - SELECT * FROM bb_online WHERE online_uid IN (9247,21)
0.000102 - SELECT groupid FROM groups_users_link WHERE uid=9247
0.000027 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 296 AND rank_max >= 296 AND rank_special = 0
0.000094 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000119 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000228 - SELECT post_id FROM bb_posts WHERE topic_id = 20669 AND pid = 0
0.000116 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 48
Usage de la mémoire: 8180056 bytes
XOOPS a mis 0.156 seconde(s) pour charger
