119 Personne(s) en ligne (99 Personne(s) connectée(s) sur Forum)
Invité(s): 119
« 1 ... 3 4 5 (6)
De Lyon (69)
Post(s): 1640
1.6 16v Dynamique 2001
De Cannes(06)
Post(s): 109
Kurupt a écrit:
www.clearvisionxenon.eu
essay ca coute rien
De IDF (77)
Post(s): 343
De IDF (77)
Post(s): 343
super-thanks !!!!
Post(s): 74
De Rosny sous bois (93)
Post(s): 374
Post(s): 374
Post(s): 1386
Post(s): 1386
Post(s): 1386
« 1 ... 3 4 5 (6)
0.000159 - SET NAMES 'utf8'
0.001299 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '716c31bc7e6c10ca6d7f62bfe185fd43'
0.000590 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000304 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 176730
0.000084 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000063 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000474 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 3321
0.000274 - SELECT * FROM bb_topics WHERE topic_id=3321
0.000031 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3321 AND approved = 1
0.000651 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3321 AND approved = 1 AND post_id < 176730
0.000058 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=3321 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 150, 30
0.000958 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =3321
0.000065 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000057 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000255 - SELECT * FROM groups
0.000324 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000854 - UPDATE online SET online_updated=1793908133, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000335 - SELECT * FROM online
0.000213 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000941 - UPDATE online SET online_updated=1793908133, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000193 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000808 - UPDATE bb_online SET online_updated= '1793908133', online_forum = '5', online_topic = '3321' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000286 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000981 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('146.255.74.188','51.194.196.20','41.125.255.42','82.167.214.23','77.46.129.173','136.158.61.103','189.244.21.13','172.58.3.57','102.22.140.32','41.90.66.113','188.161.211.83','185.191.171.15','37.236.31.34','152.232.187.183','179.101.181.163','92.71.12.92','104.164.59.165','85.208.96.195','92.253.4.98','85.208.96.210','187.191.38.32','52.167.144.173','185.81.144.73','207.216.205.195','152.232.241.165','202.46.62.96','82.42.18.213','207.46.13.127','190.115.67.84','161.0.154.77','31.105.120.31','83.194.44.102','84.127.0.115','196.207.227.206','187.143.100.139','185.191.171.11','212.81.52.143','51.36.175.83','171.225.206.168','138.219.212.106','102.31.188.101','103.60.88.13','176.28.172.22','66.249.64.7','93.140.80.213','85.208.96.199','188.70.14.227','47.72.75.67','84.251.39.202','69.94.45.234','117.1.201.141','79.126.113.226','151.244.152.177','144.76.23.204','147.235.197.213','86.161.183.94','62.201.243.9','190.72.32.230','192.140.92.212','77.249.56.215','216.73.216.84','45.15.132.23','190.171.113.137','77.141.37.114','85.208.96.194','84.115.228.123','197.234.87.122','195.81.101.149','38.62.92.246','31.105.105.204','153.67.161.192','170.168.241.31','170.168.98.220','85.208.96.193','102.221.169.47','147.235.197.197','203.168.150.141','185.191.171.1','9.246.77.143','83.167.40.95','197.204.177.62','200.71.122.182','85.208.96.211','185.191.171.16','86.108.23.158','212.142.106.186','66.249.70.202','87.15.241.104','93.202.32.229','85.252.223.77','75.198.21.33','213.230.78.181','84.54.139.62','178.157.32.95','82.146.21.17','185.61.20.244','92.208.63.146','45.179.248.199','185.122.252.43') )
0.000180 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '3321'
0.000146 - SELECT * FROM bb_online WHERE (online_topic = '3321' AND online_uid <> '0')
0.000129 - SELECT * FROM `users` WHERE uid IN (1049,3295,1779,3408,2633,5967,5762,21,841,1129,1315)
0.000238 - SELECT * FROM bb_online WHERE online_uid IN (1049,3295,1779,3408,2633,5967,5762,21,841,1129,1315)
0.000077 - SELECT groupid FROM groups_users_link WHERE uid=1049
0.000100 - SELECT groupid FROM groups_users_link WHERE uid=3295
0.000032 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 109 AND rank_max >= 109 AND rank_special = 0
0.000051 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000072 - SELECT groupid FROM groups_users_link WHERE uid=3408
0.000030 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 343 AND rank_max >= 343 AND rank_special = 0
0.000669 - SELECT groupid FROM groups_users_link WHERE uid=5967
0.000029 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 74 AND rank_max >= 74 AND rank_special = 0
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=5762
0.000185 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.005676 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000165 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000075 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000077 - SELECT groupid FROM groups_users_link WHERE uid=1129
0.000031 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1386 AND rank_max >= 1386 AND rank_special = 0
0.000050 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000128 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000033 - SELECT post_id FROM bb_posts WHERE topic_id = 3321 AND pid = 0
0.000180 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 67
Usage de la mémoire: 9654520 bytes
XOOPS a mis 0.322 seconde(s) pour charger
XOOPS Boot a mis 0.059 seconde(s) pour charger
XOOPS output init a mis 0.086 seconde(s) pour charger
Module display a mis 0.116 seconde(s) pour charger
