71 Personne(s) en ligne (53 Personne(s) connectée(s) sur Forum)
Invité(s): 71
« 1 ... 3 4 5 (6)
De Lyon (69)
Post(s): 1640
1.6 16v Dynamique 2001
De Cannes(06)
Post(s): 109
Kurupt a écrit:
www.clearvisionxenon.eu
essay ca coute rien
De IDF (77)
Post(s): 343
De IDF (77)
Post(s): 343
super-thanks !!!!
Post(s): 74
De Rosny sous bois (93)
Post(s): 374
Post(s): 374
Post(s): 1386
Post(s): 1386
Post(s): 1386
« 1 ... 3 4 5 (6)
0.000109 - SET NAMES 'utf8'
0.000975 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '97856155d8d0a7cfc29a5e0748eb9811'
0.000276 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 311936
0.000084 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000079 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000205 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 3321
0.000194 - SELECT * FROM bb_topics WHERE topic_id=3321
0.000040 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3321 AND approved = 1
0.000736 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3321 AND approved = 1 AND post_id < 311936
0.001759 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=3321 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 150, 30
0.000241 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =3321
0.000091 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000224 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000230 - UPDATE online SET online_updated=1793911979, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000208 - SELECT * FROM online
0.000265 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000255 - UPDATE online SET online_updated=1793911979, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000259 - UPDATE bb_online SET online_updated= '1793911979', online_forum = '5', online_topic = '3321' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000572 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('85.208.96.208','115.66.14.176','93.119.105.205','185.61.216.154','85.144.208.14','190.113.114.79','45.140.206.43','74.14.2.88','185.191.171.8','202.46.61.95','45.135.3.109','210.204.118.45','212.118.20.114','185.191.171.12','94.27.130.210','89.19.35.181','185.201.137.24','109.174.165.178','185.191.171.11','84.214.87.117','196.207.231.78','14.169.248.88','50.68.96.128','185.191.171.10','140.235.3.23','79.167.240.191','94.187.19.111','2.15.119.35','103.96.71.174','197.14.200.165','160.179.208.15','196.176.230.237','216.73.216.244','85.250.179.194','85.208.96.204','60.92.13.187','31.105.115.53','212.140.123.159','90.215.99.241','185.191.171.7','90.168.71.83','66.249.70.202','86.41.210.144','93.152.84.246','85.208.96.206','137.220.85.191','148.227.67.81','193.202.15.28','185.191.171.5','62.162.133.77','222.150.67.32','176.223.47.205','178.114.147.105') )
0.000160 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '3321'
0.000199 - SELECT * FROM bb_online WHERE (online_topic = '3321' AND online_uid <> '0')
0.000525 - SELECT * FROM `users` WHERE uid IN (1049,3295,1779,3408,2633,5967,5762,21,841,1129,1315)
0.000214 - SELECT * FROM bb_online WHERE online_uid IN (1049,3295,1779,3408,2633,5967,5762,21,841,1129,1315)
0.000071 - SELECT groupid FROM groups_users_link WHERE uid=1049
0.000079 - SELECT groupid FROM groups_users_link WHERE uid=3295
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 109 AND rank_max >= 109 AND rank_special = 0
0.000072 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000071 - SELECT groupid FROM groups_users_link WHERE uid=3408
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 343 AND rank_max >= 343 AND rank_special = 0
0.000090 - SELECT groupid FROM groups_users_link WHERE uid=2633
0.000169 - SELECT groupid FROM groups_users_link WHERE uid=5967
0.000086 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 74 AND rank_max >= 74 AND rank_special = 0
0.000034 - SELECT groupid FROM groups_users_link WHERE uid=5762
0.000033 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000035 - SELECT groupid FROM groups_users_link WHERE uid=1129
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1386 AND rank_max >= 1386 AND rank_special = 0
0.000059 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000103 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000035 - SELECT post_id FROM bb_posts WHERE topic_id = 3321 AND pid = 0
Total: 67
Usage de la mémoire: 9644544 bytes
XOOPS a mis 0.175 seconde(s) pour charger
