127 Personne(s) en ligne (88 Personne(s) connectée(s) sur Forum)
Invité(s): 127
« 1 ... 3 4 5 (6)
De Lyon (69)
Post(s): 1640
1.6 16v Dynamique 2001
De Cannes(06)
Post(s): 109
Kurupt a écrit:
www.clearvisionxenon.eu
essay ca coute rien
De IDF (77)
Post(s): 343
De IDF (77)
Post(s): 343
super-thanks !!!!
Post(s): 74
De Rosny sous bois (93)
Post(s): 374
Post(s): 374
Post(s): 1386
Post(s): 1386
Post(s): 1386
« 1 ... 3 4 5 (6)
0.000115 - SET NAMES 'utf8'
0.000868 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '1a8705272d45c1feca6bf62fb7e558c7'
0.000106 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000873 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 311902
0.000092 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000077 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000312 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 3321
0.000099 - SELECT * FROM bb_topics WHERE topic_id=3321
0.000027 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3321 AND approved = 1
0.000740 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3321 AND approved = 1 AND post_id < 311902
0.001664 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=3321 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 150, 30
0.000066 - SELECT * FROM bb_forums ORDER BY forum_order
0.000103 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000513 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.001137 - UPDATE online SET online_updated=1793909696, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000230 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000569 - UPDATE online SET online_updated=1793909696, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000161 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000396 - UPDATE bb_online SET online_updated= '1793909696', online_forum = '5', online_topic = '3321' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000912 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('79.126.113.226','134.249.12.43','81.107.233.148','85.208.96.211','178.165.183.57','85.208.96.199','185.191.171.19','41.90.145.229','47.185.161.5','176.140.68.217','185.191.171.5','31.134.13.169','66.249.70.202','46.128.8.6','85.208.96.210','93.186.72.243','86.108.22.32','45.224.98.209','213.74.43.238','14.180.31.5','212.237.122.181','85.208.96.198','102.100.162.122','212.70.99.192','105.186.231.116','38.252.48.53','187.62.85.75','186.29.52.91','190.109.22.234','187.84.241.112','223.123.118.247','45.145.132.1','196.179.30.174','85.208.96.197','104.164.54.197','185.191.171.14','167.253.18.109','195.81.148.212','212.159.165.209','122.8.47.151','85.208.96.195','178.115.91.172','195.81.191.106','186.94.147.99','189.178.6.81','38.46.247.87','85.208.96.207','87.241.157.54','130.49.114.247','31.134.4.161','196.75.204.67','102.206.159.84','143.44.146.127','185.191.171.3','181.132.130.172','38.210.164.113','118.161.99.51','185.191.171.13','90.242.195.220','95.184.78.90','151.177.104.88','82.24.210.183','185.147.100.233','41.248.127.184','216.73.216.244','51.175.158.185','105.27.128.74','87.49.45.157','213.217.205.123','184.163.63.195','196.190.132.66','157.55.39.7','85.208.96.196','88.244.103.134','157.100.137.225','179.63.191.100','179.6.23.203','94.249.49.68','152.232.247.173','40.77.167.235','24.144.186.105','73.149.160.222','64.67.107.176','66.249.70.192','45.176.235.213','85.81.42.41','217.145.224.65','31.105.124.128') )
0.000168 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '3321'
0.000198 - SELECT * FROM bb_online WHERE (online_topic = '3321' AND online_uid <> '0')
0.000500 - SELECT * FROM `users` WHERE uid IN (1049,3295,1779,3408,2633,5967,5762,21,841,1129,1315)
0.000237 - SELECT * FROM bb_online WHERE online_uid IN (1049,3295,1779,3408,2633,5967,5762,21,841,1129,1315)
0.000074 - SELECT groupid FROM groups_users_link WHERE uid=1049
0.000077 - SELECT groupid FROM groups_users_link WHERE uid=3295
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 109 AND rank_max >= 109 AND rank_special = 0
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=3408
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 343 AND rank_max >= 343 AND rank_special = 0
0.000174 - SELECT groupid FROM groups_users_link WHERE uid=5967
0.000028 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 74 AND rank_max >= 74 AND rank_special = 0
0.000024 - SELECT groupid FROM groups_users_link WHERE uid=5762
0.000041 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=1129
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1386 AND rank_max >= 1386 AND rank_special = 0
0.002146 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000033 - SELECT post_id FROM bb_posts WHERE topic_id = 3321 AND pid = 0
0.000141 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 66
Usage de la mémoire: 9640616 bytes
XOOPS a mis 0.176 seconde(s) pour charger
