44 Personne(s) en ligne (44 Personne(s) connectée(s) sur Forum)
Invité(s): 44
« 1 ... 3 4 5 (6)
De Lyon (69)
Post(s): 1640
1.6 16v Dynamique 2001
De Cannes(06)
Post(s): 109
Kurupt a écrit:
www.clearvisionxenon.eu
essay ca coute rien
De IDF (77)
Post(s): 343
De IDF (77)
Post(s): 343
super-thanks !!!!
Post(s): 74
De Rosny sous bois (93)
Post(s): 374
Post(s): 374
Post(s): 1386
Post(s): 1386
Post(s): 1386
« 1 ... 3 4 5 (6)
0.000126 - SET NAMES 'utf8'
0.001128 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '3408df8823e44d1a9d8753b565053625'
0.000102 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000395 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 185448
0.000073 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000094 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000075 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000236 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 3321
0.000100 - SELECT * FROM bb_topics WHERE topic_id=3321
0.000028 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3321 AND approved = 1
0.000787 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3321 AND approved = 1 AND post_id < 185448
0.000447 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=3321 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 150, 30
0.023252 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =3321
0.000128 - SELECT * FROM groups
0.000208 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.000771 - UPDATE online SET online_updated=1777586969, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.000203 - SELECT * FROM online
0.000216 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.000999 - UPDATE online SET online_updated=1777586969, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.000179 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.001231 - UPDATE bb_online SET online_updated= '1777586969', online_forum = '5', online_topic = '3321' WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.000157 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000595 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('66.249.66.68','66.249.66.70','66.249.66.69','66.249.66.77','85.208.96.204','85.208.96.194','51.195.244.136','66.249.66.78','170.79.41.200','207.46.13.6','185.191.171.12','66.249.66.73','85.208.96.206','51.91.250.17','85.208.96.197','144.76.23.203','85.208.96.200','66.249.66.72','177.221.106.161','51.195.244.180','198.244.168.75','57.129.81.152','185.191.171.3','66.249.66.74','202.8.42.223','66.249.66.75','66.249.66.76','66.249.66.71','185.191.171.16','85.208.96.211','45.131.217.193','85.208.96.203','51.91.254.244','51.38.112.81','198.244.242.184','85.241.151.217','185.191.171.10','38.25.51.37','216.73.217.23','185.191.171.13','85.208.96.198','85.208.96.193','40.77.167.23','85.208.96.205') )
0.000141 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '3321'
0.000173 - SELECT * FROM bb_online WHERE (online_topic = '3321' AND online_uid <> '0')
0.000059 - SELECT * FROM `users` WHERE uid IN (1049,3295,1779,3408,2633,5967,5762,21,841,1129,1315)
0.000234 - SELECT * FROM bb_online WHERE online_uid IN (1049,3295,1779,3408,2633,5967,5762,21,841,1129,1315)
0.000039 - SELECT groupid FROM groups_users_link WHERE uid=1049
0.000046 - SELECT groupid FROM groups_users_link WHERE uid=3295
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 109 AND rank_max >= 109 AND rank_special = 0
0.000097 - SELECT groupid FROM groups_users_link WHERE uid=3408
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 343 AND rank_max >= 343 AND rank_special = 0
0.000033 - SELECT groupid FROM groups_users_link WHERE uid=2633
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=5967
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 74 AND rank_max >= 74 AND rank_special = 0
0.000026 - SELECT groupid FROM groups_users_link WHERE uid=5762
0.000095 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=1129
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1386 AND rank_max >= 1386 AND rank_special = 0
0.000050 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000023 - SELECT post_id FROM bb_posts WHERE topic_id = 3321 AND pid = 0
Total: 67
Usage de la mémoire: 9627160 bytes
XOOPS a mis 0.250 seconde(s) pour charger
Module init a mis 0.038 seconde(s) pour charger
