134 Personne(s) en ligne (92 Personne(s) connectée(s) sur Forum)
Invité(s): 134
« 1 ... 3 4 5 (6)
De Lyon (69)
Post(s): 1640
1.6 16v Dynamique 2001
De Cannes(06)
Post(s): 109
Kurupt a écrit:
www.clearvisionxenon.eu
essay ca coute rien
De IDF (77)
Post(s): 343
De IDF (77)
Post(s): 343
super-thanks !!!!
Post(s): 74
De Rosny sous bois (93)
Post(s): 374
Post(s): 374
Post(s): 1386
Post(s): 1386
Post(s): 1386
« 1 ... 3 4 5 (6)
0.000216 - SET NAMES 'utf8'
0.000052 - SET SQL_BIG_SELECTS = 1
0.001265 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '16e68482deac9ff667d2dd5e390a50ce'
0.000068 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000227 - SELECT * FROM bb_topics WHERE topic_id=3321
0.000053 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000035 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000280 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 3321
0.000028 - SELECT * FROM bb_topics WHERE topic_id=3321
0.000033 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3321 AND approved = 1
0.002443 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=3321 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 150, 30
0.000709 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =3321
0.000054 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.015853 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000709 - UPDATE online SET online_updated=1793910030, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000424 - SELECT * FROM online
0.039519 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.001892 - UPDATE online SET online_updated=1793910030, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000250 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.001274 - UPDATE bb_online SET online_updated= '1793910030', online_forum = '5', online_topic = '3321' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000357 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001339 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('202.46.62.35','5.241.139.159','31.134.3.105','213.6.102.191','86.41.130.37','91.127.8.193','86.176.131.23','186.77.206.155','122.8.45.30','41.214.3.214','195.36.204.216','41.60.90.222','116.96.78.115','41.208.141.74','93.152.80.68','216.147.125.54','165.162.147.132','95.84.66.119','45.80.107.214','185.101.21.206','185.191.171.5','66.249.84.33','46.128.8.6','178.40.240.129','38.51.121.60','79.177.131.91','185.191.171.1','200.149.89.194','31.105.105.36','41.74.138.65','23.230.40.155','85.208.96.212','178.43.244.182','109.242.90.144','157.22.72.59','185.191.171.16','93.152.85.28','176.124.236.241','90.36.61.149','202.46.61.135','202.46.62.32','157.55.39.204','45.65.167.138','109.245.151.204','38.74.245.120','109.196.67.205','45.66.210.122','92.208.38.143','198.91.152.111','221.153.124.214','155.4.206.246','186.91.18.171','106.73.159.193','41.83.45.142','212.93.153.39','188.151.133.137','185.191.171.11','109.81.12.155','202.46.61.89','197.146.138.106','87.125.178.27','88.0.91.243','173.33.114.42','190.145.240.183','14.231.252.236','185.191.171.13','199.201.92.59','85.208.96.209','216.73.216.244','66.9.171.28','200.180.238.253','177.70.165.214','85.208.96.193','91.82.240.128','85.217.249.150','152.249.11.244','90.14.5.65','93.117.164.200','201.4.71.213','213.232.122.23','85.208.96.206','185.244.154.87','190.99.23.153','40.77.167.235','66.249.70.192','138.84.47.240','134.249.12.43','201.180.185.250','191.108.51.228','87.83.122.151','40.77.167.121','2.215.146.133') )
0.000232 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '3321'
0.000378 - SELECT * FROM bb_online WHERE (online_topic = '3321' AND online_uid <> '0')
0.000084 - SELECT * FROM `users` WHERE uid IN (1049,3295,1779,3408,2633,5967,5762,21,841,1129,1315)
0.000300 - SELECT * FROM bb_online WHERE online_uid IN (1049,3295,1779,3408,2633,5967,5762,21,841,1129,1315)
0.000044 - SELECT groupid FROM groups_users_link WHERE uid=1049
0.000058 - SELECT groupid FROM groups_users_link WHERE uid=3295
0.000032 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 109 AND rank_max >= 109 AND rank_special = 0
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=3408
0.000029 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 343 AND rank_max >= 343 AND rank_special = 0
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=2633
0.000043 - SELECT groupid FROM groups_users_link WHERE uid=5967
0.000030 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 74 AND rank_max >= 74 AND rank_special = 0
0.000038 - SELECT groupid FROM groups_users_link WHERE uid=5762
0.000049 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000044 - SELECT groupid FROM groups_users_link WHERE uid=1129
0.000031 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1386 AND rank_max >= 1386 AND rank_special = 0
0.000045 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000115 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000029 - SELECT post_id FROM bb_posts WHERE topic_id = 3321 AND pid = 0
Total: 66
Usage de la mémoire: 9633624 bytes
XOOPS a mis 0.320 seconde(s) pour charger
XOOPS output init a mis 0.111 seconde(s) pour charger
Module display a mis 0.098 seconde(s) pour charger
