76 Personne(s) en ligne (61 Personne(s) connectée(s) sur Forum)
Invité(s): 76
Sarah Keaton.
Post(s): 269
Post(s): 3535
Renault power for ever !
Post(s): 269
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 269
Post(s): 87
question mal placée.
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 269
Jcrois que c'est 250 en fait
type mine DAOG05
Post(s): 269
Pare Brise: 210,98HT
Joint: 21,08HT
Cales x2: 0,98x2HT
Soit: 234,32HT
Donc 279,88TTC
tu as pas la réf renault ?
type mine: DAOG05
mise en circulation: 03/96
n°moteur: F3R R 750
n° fabrication: H000800
voila ya toute les info
boitier : 7701474249 à 100€
tarif approximatif !!!
Post(s): 1912
pare brise :
7700828364
210.98 HT
anti brouillard avt G :
7701045718
71.56 HT
306 cab 1.6 8s
yamaha XJ600N
De Firenze, Italie
Post(s): 221
stunteur62 a écrit:
pare brise :
7700828364
210.98 HT
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 175
I love this.
Post(s): 34
bonsoir,
merci !
Pièce inconnue pour moi.
0.000142 - SET NAMES 'utf8'
0.001103 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '7f0025eec725005998484b8296d0e9de'
0.000411 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 272097
0.000057 - SELECT * FROM bb_forums WHERE forum_id = 14
0.000032 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '14' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000218 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 10007
0.000108 - SELECT * FROM bb_topics WHERE topic_id=10007
0.000119 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10007 AND approved = 1
0.001085 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10007 AND approved = 1 AND post_id < 272097
0.001057 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=10007 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 270, 30
0.000680 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =10007
0.000077 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000257 - DELETE FROM online WHERE online_updated < 1793912383
0.000208 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.128'
0.000145 - UPDATE online SET online_updated=1793912683, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.128'
0.000221 - SELECT * FROM online
0.000244 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.128'
0.000493 - UPDATE online SET online_updated=1793912684, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.128'
0.000144 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.128'
0.000162 - UPDATE bb_online SET online_updated= '1793912684', online_forum = '14', online_topic = '10007' WHERE online_uid = 0 AND online_ip='216.73.217.128'
0.000197 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000607 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('193.71.149.229','5.175.156.179','85.208.96.209','85.208.96.201','157.55.39.201','157.15.47.148','62.152.9.21','190.142.161.133','185.191.171.7','196.249.124.211','185.191.171.3','190.99.23.2','185.191.171.12','27.125.241.28','45.66.210.57','78.72.178.137','66.249.70.193','185.191.171.16','5.178.10.1','66.249.64.7','179.24.209.135','202.46.62.111','85.208.96.207','178.51.238.194','80.112.8.111','37.209.130.2','85.208.96.212','37.152.136.115','40.77.167.71','37.231.157.245','185.191.171.1','37.67.207.196','31.105.106.243','84.15.223.87','194.104.11.149','178.120.54.4','102.202.244.137','94.176.93.10','178.237.227.49','181.188.116.156','80.201.160.34','83.131.97.78','85.208.96.202','85.208.96.193','86.152.43.166','202.46.61.100','178.175.53.150','85.144.208.14','85.208.96.194','82.29.221.49','27.114.180.12','112.204.167.191','66.249.70.192','92.244.136.16','195.170.201.143','81.193.194.30','185.61.218.169','143.105.123.131','82.21.236.55','5.77.205.126','216.73.217.128') )
0.000190 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '10007'
0.000120 - SELECT * FROM bb_online WHERE (online_topic = '10007' AND online_uid <> '0')
0.000095 - SELECT * FROM `users` WHERE uid IN (3726,4216,21,1273,41,3711,5358,3283,5251,4613)
0.000238 - SELECT * FROM bb_online WHERE online_uid IN (3726,4216,21,1273,41,3711,5358,3283,5251,4613)
0.000067 - SELECT groupid FROM groups_users_link WHERE uid=4216
0.000027 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 269 AND rank_max >= 269 AND rank_special = 0
0.000045 - SELECT groupid FROM groups_users_link WHERE uid=1273
0.000062 - SELECT groupid FROM groups_users_link WHERE uid=41
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1912 AND rank_max >= 1912 AND rank_special = 0
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000079 - SELECT groupid FROM groups_users_link WHERE uid=5358
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 87 AND rank_max >= 87 AND rank_special = 0
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=3283
0.000024 - SELECT groupid FROM groups_users_link WHERE uid=5251
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 175 AND rank_max >= 175 AND rank_special = 0
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=4613
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 34 AND rank_max >= 34 AND rank_special = 0
0.000153 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000064 - SELECT post_id FROM bb_posts WHERE topic_id = 10007 AND pid = 0
0.000154 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Usage de la mémoire: 10044640 bytes
XOOPS a mis 0.940 seconde(s) pour charger
XOOPS output init a mis 0.224 seconde(s) pour charger
Page rendering a mis 0.623 seconde(s) pour charger
