71 Personne(s) en ligne (52 Personne(s) connectée(s) sur Forum)
Invité(s): 71
Sarah Keaton.
Post(s): 269
Post(s): 3535
Renault power for ever !
Post(s): 269
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 269
Post(s): 87
question mal placée.
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 269
Jcrois que c'est 250 en fait
type mine DAOG05
Post(s): 269
Pare Brise: 210,98HT
Joint: 21,08HT
Cales x2: 0,98x2HT
Soit: 234,32HT
Donc 279,88TTC
tu as pas la réf renault ?
type mine: DAOG05
mise en circulation: 03/96
n°moteur: F3R R 750
n° fabrication: H000800
voila ya toute les info
boitier : 7701474249 à 100€
tarif approximatif !!!
Post(s): 1912
pare brise :
7700828364
210.98 HT
anti brouillard avt G :
7701045718
71.56 HT
306 cab 1.6 8s
yamaha XJ600N
De Firenze, Italie
Post(s): 221
stunteur62 a écrit:
pare brise :
7700828364
210.98 HT
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 175
I love this.
Post(s): 34
bonsoir,
merci !
Pièce inconnue pour moi.
0.000167 - SET NAMES 'utf8'
0.000063 - SET SQL_BIG_SELECTS = 1
0.001280 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '97856155d8d0a7cfc29a5e0748eb9811'
0.000349 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 273361
0.000059 - SELECT * FROM bb_forums WHERE forum_id = 14
0.000043 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '14' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000279 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 10007
0.000142 - SELECT * FROM bb_topics WHERE topic_id=10007
0.000039 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10007 AND approved = 1
0.002082 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10007 AND approved = 1 AND post_id < 273361
0.004278 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=10007 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 270, 30
0.000468 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =10007
0.000156 - DELETE FROM online WHERE online_updated < 1793911640
0.000216 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000543 - UPDATE online SET online_updated=1793911940, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000199 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000419 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000362 - UPDATE online SET online_updated=1793911940, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000198 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000616 - UPDATE bb_online SET online_updated= '1793911940', online_forum = '14', online_topic = '10007' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000275 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000925 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('85.208.96.208','115.66.14.176','93.119.105.205','185.61.216.154','85.144.208.14','190.113.114.79','45.140.206.43','74.14.2.88','185.191.171.8','202.46.61.95','45.135.3.109','210.204.118.45','212.118.20.114','152.203.231.158','185.191.171.12','94.27.130.210','185.201.137.24','109.174.165.178','185.191.171.11','84.214.87.117','14.169.248.88','50.68.96.128','185.191.171.10','140.235.3.23','79.167.240.191','94.187.19.111','2.15.119.35','103.96.71.174','197.14.200.165','160.179.208.15','196.176.230.237','216.73.216.244','85.250.179.194','85.208.96.204','60.92.13.187','31.105.115.53','212.140.123.159','90.215.99.241','185.191.171.7','90.168.71.83','66.249.70.202','86.41.210.144','202.46.62.2','85.208.96.206','78.113.134.36','148.227.67.81','193.202.15.28','185.191.171.5','62.162.133.77','222.150.67.32','176.223.47.205','170.239.71.205') )
0.000225 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '10007'
0.000463 - SELECT * FROM bb_online WHERE (online_topic = '10007' AND online_uid <> '0')
0.000614 - SELECT * FROM `users` WHERE uid IN (3726,4216,21,1273,41,3711,5358,3283,5251,4613)
0.000286 - SELECT * FROM bb_online WHERE online_uid IN (3726,4216,21,1273,41,3711,5358,3283,5251,4613)
0.000047 - SELECT groupid FROM groups_users_link WHERE uid=4216
0.000031 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 269 AND rank_max >= 269 AND rank_special = 0
0.000104 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000051 - SELECT groupid FROM groups_users_link WHERE uid=1273
0.000043 - SELECT groupid FROM groups_users_link WHERE uid=41
0.000028 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1912 AND rank_max >= 1912 AND rank_special = 0
0.000052 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000331 - SELECT groupid FROM groups_users_link WHERE uid=5358
0.000037 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 87 AND rank_max >= 87 AND rank_special = 0
0.000038 - SELECT groupid FROM groups_users_link WHERE uid=3283
0.000032 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 9
0.000036 - SELECT groupid FROM groups_users_link WHERE uid=5251
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 175 AND rank_max >= 175 AND rank_special = 0
0.000267 - SELECT groupid FROM groups_users_link WHERE uid=4613
0.000034 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 34 AND rank_max >= 34 AND rank_special = 0
0.000094 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000043 - SELECT post_id FROM bb_posts WHERE topic_id = 10007 AND pid = 0
Usage de la mémoire: 10044832 bytes
