75 Personne(s) en ligne (55 Personne(s) connectée(s) sur Forum)
Invité(s): 75
Sarah Keaton.
Post(s): 269
Post(s): 3535
Renault power for ever !
Post(s): 269
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 269
Post(s): 87
question mal placée.
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 269
Jcrois que c'est 250 en fait
type mine DAOG05
Post(s): 269
Pare Brise: 210,98HT
Joint: 21,08HT
Cales x2: 0,98x2HT
Soit: 234,32HT
Donc 279,88TTC
tu as pas la réf renault ?
type mine: DAOG05
mise en circulation: 03/96
n°moteur: F3R R 750
n° fabrication: H000800
voila ya toute les info
boitier : 7701474249 à 100€
tarif approximatif !!!
Post(s): 1912
pare brise :
7700828364
210.98 HT
anti brouillard avt G :
7701045718
71.56 HT
306 cab 1.6 8s
yamaha XJ600N
De Firenze, Italie
Post(s): 221
stunteur62 a écrit:
pare brise :
7700828364
210.98 HT
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 175
I love this.
Post(s): 34
bonsoir,
merci !
Pièce inconnue pour moi.
0.000115 - SET NAMES 'utf8'
0.000863 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'd4fa7307aad1bcb40f2e6130f5ac11f0'
0.000128 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000260 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 272399
0.000103 - SELECT * FROM bb_forums WHERE forum_id = 14
0.000026 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000028 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '14' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000210 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 10007
0.000151 - SELECT * FROM bb_topics WHERE topic_id=10007
0.000032 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10007 AND approved = 1
0.001067 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10007 AND approved = 1 AND post_id < 272399
0.000049 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=10007 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 270, 30
0.000277 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000588 - UPDATE online SET online_updated=1793911991, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000157 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000275 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000487 - UPDATE online SET online_updated=1793911991, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000175 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000333 - UPDATE bb_online SET online_updated= '1793911991', online_forum = '14', online_topic = '10007' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000864 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('85.208.96.208','115.66.14.176','93.119.105.205','185.61.216.154','85.144.208.14','190.113.114.79','45.140.206.43','74.14.2.88','185.191.171.8','202.46.61.95','45.135.3.109','210.204.118.45','212.118.20.114','185.191.171.12','94.27.130.210','89.19.35.181','185.201.137.24','109.174.165.178','185.191.171.11','84.214.87.117','196.207.231.78','14.169.248.88','50.68.96.128','185.191.171.10','140.235.3.23','79.167.240.191','94.187.19.111','2.15.119.35','103.96.71.174','197.14.200.165','160.179.208.15','196.176.230.237','216.73.216.244','85.250.179.194','85.208.96.204','60.92.13.187','31.105.115.53','212.140.123.159','90.215.99.241','185.191.171.7','90.168.71.83','66.249.70.202','86.41.210.144','93.152.84.246','85.208.96.206','137.220.85.191','148.227.67.81','193.202.15.28','185.191.171.5','62.162.133.77','138.84.47.107','185.191.171.4','185.191.171.6','222.150.67.32','176.223.47.205','178.114.147.105') )
0.000234 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '10007'
0.000285 - SELECT * FROM bb_online WHERE (online_topic = '10007' AND online_uid <> '0')
0.000078 - SELECT * FROM `users` WHERE uid IN (3726,4216,21,1273,41,3711,5358,3283,5251,4613)
0.000324 - SELECT * FROM bb_online WHERE online_uid IN (3726,4216,21,1273,41,3711,5358,3283,5251,4613)
0.000050 - SELECT groupid FROM groups_users_link WHERE uid=4216
0.000034 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 269 AND rank_max >= 269 AND rank_special = 0
0.000048 - SELECT groupid FROM groups_users_link WHERE uid=1273
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=41
0.000062 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1912 AND rank_max >= 1912 AND rank_special = 0
0.000269 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000058 - SELECT groupid FROM groups_users_link WHERE uid=5358
0.000031 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 87 AND rank_max >= 87 AND rank_special = 0
0.000035 - SELECT groupid FROM groups_users_link WHERE uid=3283
0.000034 - SELECT groupid FROM groups_users_link WHERE uid=5251
0.000020 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 175 AND rank_max >= 175 AND rank_special = 0
0.000039 - SELECT groupid FROM groups_users_link WHERE uid=4613
0.000030 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 34 AND rank_max >= 34 AND rank_special = 0
0.000023 - SELECT post_id FROM bb_posts WHERE topic_id = 10007 AND pid = 0
Usage de la mémoire: 10045216 bytes
XOOPS output init a mis 0.032 seconde(s) pour charger
Module display a mis 0.058 seconde(s) pour charger
