111 Personne(s) en ligne (95 Personne(s) connectée(s) sur Forum)
Invité(s): 111
Sarah Keaton.
Post(s): 269
Post(s): 3535
Renault power for ever !
Post(s): 269
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 269
Post(s): 87
question mal placée.
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 269
Jcrois que c'est 250 en fait
type mine DAOG05
Post(s): 269
Pare Brise: 210,98HT
Joint: 21,08HT
Cales x2: 0,98x2HT
Soit: 234,32HT
Donc 279,88TTC
tu as pas la réf renault ?
type mine: DAOG05
mise en circulation: 03/96
n°moteur: F3R R 750
n° fabrication: H000800
voila ya toute les info
boitier : 7701474249 à 100€
tarif approximatif !!!
Post(s): 1912
pare brise :
7700828364
210.98 HT
anti brouillard avt G :
7701045718
71.56 HT
306 cab 1.6 8s
yamaha XJ600N
De Firenze, Italie
Post(s): 221
stunteur62 a écrit:
pare brise :
7700828364
210.98 HT
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 175
I love this.
Post(s): 34
bonsoir,
merci !
Pièce inconnue pour moi.
0.000119 - SET NAMES 'utf8'
0.001039 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '4a702ff3dd6ad42de8836f2c86fec3fa'
0.000360 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 272461
0.000082 - SELECT * FROM bb_forums WHERE forum_id = 14
0.000063 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '14' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000241 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 10007
0.000105 - SELECT * FROM bb_topics WHERE topic_id=10007
0.000028 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10007 AND approved = 1
0.001611 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10007 AND approved = 1 AND post_id < 272461
0.000054 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=10007 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 270, 30
0.000136 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000192 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000705 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000145 - UPDATE online SET online_updated=1793911268, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000664 - SELECT * FROM online
0.001383 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000213 - UPDATE online SET online_updated=1793911268, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000316 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000215 - UPDATE bb_online SET online_updated= '1793911268', online_forum = '14', online_topic = '10007' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000373 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001454 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('148.227.67.62','37.215.40.60','38.41.12.135','190.153.45.144','189.239.72.142','109.136.84.164','195.81.171.252','138.97.161.39','178.51.238.194','202.46.62.27','37.69.217.45','190.99.23.2','119.152.199.90','108.53.188.44','109.161.178.25','85.81.42.49','79.116.172.152','81.88.75.25','79.167.240.191','181.103.67.170','151.236.176.108','140.235.171.48','31.105.126.109','85.100.198.102','185.191.171.17','178.226.143.182','103.31.178.255','178.20.214.169','82.22.239.170','144.76.23.197','39.39.172.93','119.111.248.43','197.63.212.233','128.127.120.23','80.201.102.222','88.238.176.71','85.208.96.200','202.46.61.113','181.161.100.208','169.224.73.135','41.102.224.22','170.81.249.234','45.38.189.191','38.248.184.119','85.208.96.197','38.224.56.245','102.90.80.170','200.36.219.117','185.191.171.11','46.55.116.165','102.206.240.254','94.76.169.162','78.99.210.44','162.141.20.58','37.236.31.36','190.167.147.84','94.154.113.136','185.191.171.4','179.125.133.104','197.206.54.61','216.73.216.244','201.211.114.38','73.104.31.96','78.173.54.138','179.116.104.57','85.104.196.99','167.58.222.152','91.220.41.11','172.83.252.204','102.89.69.71','36.236.161.133','88.201.125.92','46.249.236.184','185.191.171.6','85.208.96.194','193.104.126.225','94.187.23.75','50.117.66.255','156.201.140.216','195.135.246.197','186.109.154.164','177.37.42.218','114.130.187.225','187.198.120.191','145.223.2.163','177.18.111.200','5.29.20.88','130.193.229.37','102.97.32.15','39.63.199.218','191.179.62.78','205.234.123.61','181.98.244.82','14.162.97.97','85.208.96.198') )
0.000304 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '10007'
0.000299 - SELECT * FROM bb_online WHERE (online_topic = '10007' AND online_uid <> '0')
0.000086 - SELECT * FROM `users` WHERE uid IN (3726,4216,21,1273,41,3711,5358,3283,5251,4613)
0.000422 - SELECT * FROM bb_online WHERE online_uid IN (3726,4216,21,1273,41,3711,5358,3283,5251,4613)
0.000052 - SELECT groupid FROM groups_users_link WHERE uid=4216
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 269 AND rank_max >= 269 AND rank_special = 0
0.000410 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000197 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000057 - SELECT groupid FROM groups_users_link WHERE uid=1273
0.000043 - SELECT groupid FROM groups_users_link WHERE uid=41
0.000029 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1912 AND rank_max >= 1912 AND rank_special = 0
0.000044 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000048 - SELECT groupid FROM groups_users_link WHERE uid=5358
0.000029 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 87 AND rank_max >= 87 AND rank_special = 0
0.000039 - SELECT groupid FROM groups_users_link WHERE uid=3283
0.000035 - SELECT groupid FROM groups_users_link WHERE uid=5251
0.000032 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 175 AND rank_max >= 175 AND rank_special = 0
0.000044 - SELECT groupid FROM groups_users_link WHERE uid=4613
0.000042 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 34 AND rank_max >= 34 AND rank_special = 0
0.000137 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000029 - SELECT post_id FROM bb_posts WHERE topic_id = 10007 AND pid = 0
0.000138 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Usage de la mémoire: 10061576 bytes
XOOPS a mis 0.248 seconde(s) pour charger
