170 Personne(s) en ligne (138 Personne(s) connectée(s) sur Forum)
Invité(s): 170
Sarah Keaton.
Post(s): 269
Post(s): 3535
Renault power for ever !
Post(s): 269
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 269
Post(s): 87
question mal placée.
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 269
Jcrois que c'est 250 en fait
type mine DAOG05
Post(s): 269
Pare Brise: 210,98HT
Joint: 21,08HT
Cales x2: 0,98x2HT
Soit: 234,32HT
Donc 279,88TTC
tu as pas la réf renault ?
type mine: DAOG05
mise en circulation: 03/96
n°moteur: F3R R 750
n° fabrication: H000800
voila ya toute les info
boitier : 7701474249 à 100€
tarif approximatif !!!
Post(s): 1912
pare brise :
7700828364
210.98 HT
anti brouillard avt G :
7701045718
71.56 HT
306 cab 1.6 8s
yamaha XJ600N
De Firenze, Italie
Post(s): 221
stunteur62 a écrit:
pare brise :
7700828364
210.98 HT
Post(s): 1912
306 cab 1.6 8s
yamaha XJ600N
Post(s): 175
I love this.
Post(s): 34
bonsoir,
merci !
Pièce inconnue pour moi.
0.000108 - SET NAMES 'utf8'
0.001061 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'a1d78132e688b37b10b439ca1e2a910e'
0.000379 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 273499
0.000111 - SELECT * FROM bb_forums WHERE forum_id = 14
0.000069 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '14' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000284 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 10007
0.000230 - SELECT * FROM bb_topics WHERE topic_id=10007
0.000062 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10007 AND approved = 1
0.001161 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10007 AND approved = 1 AND post_id < 273499
0.000050 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=10007 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 270, 30
0.000132 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000076 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000294 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000252 - UPDATE online SET online_updated=1789934331, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000305 - SELECT * FROM online
0.000149 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000178 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000187 - UPDATE online SET online_updated=1789934331, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000148 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000362 - UPDATE bb_online SET online_updated= '1789934331', online_forum = '14', online_topic = '10007' WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.001166 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('35.254.231.19','136.115.148.7','204.1.240.28','35.254.235.190','34.41.163.232','34.44.37.232','34.66.127.248','34.136.111.60','34.28.60.93','34.29.246.143','34.173.64.78','136.114.190.91','35.255.247.90','47.197.139.224','34.42.190.171','40.77.167.7','35.255.70.226','66.249.68.192','35.224.103.75','188.54.20.55','34.41.65.37','67.190.114.61','34.27.43.36','35.226.130.30','35.222.110.111','34.44.200.48','104.154.189.181','2.58.13.142','34.170.20.48','35.255.232.183','136.64.154.238','35.225.10.214','34.60.251.45','136.114.251.171','34.29.26.240','35.232.208.144','34.27.90.241','35.225.182.77','34.59.220.183','35.239.248.73','85.208.96.205','34.67.245.67','220.181.108.111','34.29.229.26','104.154.87.0','34.56.106.168','34.134.224.139','34.10.138.17','34.58.244.105','67.102.22.10','136.116.59.242','34.133.188.217','34.63.146.186','34.44.229.100','34.134.185.175','71.135.13.166','35.238.73.253','216.73.217.83','34.135.47.220','34.10.254.204','34.133.64.91','150.228.105.75','34.45.53.200','35.223.180.90','136.115.16.60','35.225.72.94','35.225.92.119','34.63.130.210','34.69.172.88','185.191.171.9','85.208.96.202','34.172.179.139','34.46.146.70','104.165.12.155','34.9.131.229','136.112.169.254','34.66.45.93','34.172.220.235','34.27.99.191','34.135.218.57','35.255.220.188','136.119.145.242','34.30.52.134','34.9.203.105','34.27.5.65','35.222.231.60','34.173.138.43','136.65.73.35','85.208.96.193','35.239.226.56','34.122.252.130','34.55.37.33','193.121.217.207','52.167.144.169','66.249.79.3','35.192.131.166','34.68.177.213','88.181.229.138','35.226.106.205','34.57.28.101','136.112.177.219','34.46.92.63','34.10.108.251','181.163.111.172','34.10.84.36','35.253.40.20','34.28.219.45','35.254.195.237','34.135.98.122','34.132.16.45','35.254.55.111','35.184.42.130','34.57.115.209','181.4.82.128','66.249.68.193','34.9.180.63','35.202.107.105','35.239.86.222','34.10.194.123','104.198.177.225','34.28.30.77','34.59.183.133','136.111.73.51','169.224.96.22','34.135.220.83','35.202.11.48','104.197.166.106','136.65.206.196','136.65.57.107','34.61.77.59','66.249.68.194','136.113.248.41','136.114.178.72','34.61.148.235','88.253.49.122','34.55.227.40','34.68.97.129','188.230.193.162') )
0.000178 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '10007'
0.000183 - SELECT * FROM bb_online WHERE (online_topic = '10007' AND online_uid <> '0')
0.000094 - SELECT * FROM `users` WHERE uid IN (3726,4216,21,1273,41,3711,5358,3283,5251,4613)
0.000214 - SELECT * FROM bb_online WHERE online_uid IN (3726,4216,21,1273,41,3711,5358,3283,5251,4613)
0.000086 - SELECT groupid FROM groups_users_link WHERE uid=4216
0.000027 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 269 AND rank_max >= 269 AND rank_special = 0
0.000070 - SELECT groupid FROM groups_users_link WHERE uid=1273
0.000069 - SELECT groupid FROM groups_users_link WHERE uid=41
0.000030 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1912 AND rank_max >= 1912 AND rank_special = 0
0.000033 - SELECT groupid FROM groups_users_link WHERE uid=5358
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 87 AND rank_max >= 87 AND rank_special = 0
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=3283
0.000022 - SELECT groupid FROM groups_users_link WHERE uid=5251
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 175 AND rank_max >= 175 AND rank_special = 0
0.000058 - SELECT groupid FROM groups_users_link WHERE uid=4613
0.000034 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 34 AND rank_max >= 34 AND rank_special = 0
0.000128 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000027 - SELECT post_id FROM bb_posts WHERE topic_id = 10007 AND pid = 0
Usage de la mémoire: 10043800 bytes
