103 Personne(s) en ligne (70 Personne(s) connectée(s) sur Forum)
Invité(s): 103
« 1 2 3 (4) 5 6 7 ... 12 »
Post(s): 1175
tu m'etonne !!
Post(s): 958
rouler a 80km pas plus ptdr
De Vitry le françois
Post(s): 520
:lovemegane
Post(s): 520
:lovemegane
Post(s): 1001
Post(s): 1175
Post(s): 1001
+1
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
De 38
Post(s): 114
trés belle voiture
Mégane Coupé1.6 16s rsi :-)
Post(s): 958
il me faut 150litres par sub
Ca fait beaucoup.
Post(s): 958
Post(s): 958
0.000120 - SET NAMES 'utf8'
0.001115 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'fd4cd7c8bd69e960e71707c63c1a3f15'
0.000316 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 226407
0.000066 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000114 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000042 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000326 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9745
0.000141 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000030 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1
0.000652 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1 AND post_id < 226407
0.000050 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9745 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.000635 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.002437 - SELECT * FROM groups
0.000074 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000241 - DELETE FROM online WHERE online_updated < 1793909475
0.000389 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000153 - UPDATE online SET online_updated=1793909775, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000330 - SELECT * FROM online
0.000287 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000269 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000441 - UPDATE online SET online_updated=1793909775, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000221 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000500 - UPDATE bb_online SET online_updated= '1793909775', online_forum = '5', online_topic = '9745' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000265 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000881 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('79.126.113.226','134.249.12.43','81.107.233.148','85.208.96.211','178.165.183.57','85.208.96.199','185.191.171.19','41.90.145.229','47.185.161.5','176.140.68.217','185.191.171.5','31.134.13.169','66.249.70.202','46.128.8.6','85.208.96.210','93.186.72.243','178.43.244.182','38.252.48.53','85.208.96.197','104.164.54.197','185.191.171.14','167.253.18.109','195.81.148.212','212.159.165.209','122.8.47.151','85.208.96.195','178.115.91.172','195.81.191.106','186.94.147.99','189.178.6.81','38.46.247.87','90.233.195.169','85.208.96.207','27.79.121.243','87.241.157.54','130.49.114.247','31.134.4.161','196.75.204.67','102.206.159.84','143.44.146.127','185.191.171.3','181.132.130.172','38.210.164.113','118.161.99.51','185.191.171.13','199.201.92.59','82.24.210.183','185.147.100.233','41.248.127.184','216.73.216.244','66.9.171.28','184.163.63.195','157.55.39.7','91.82.240.128','85.208.96.196','94.249.49.68','201.4.71.213','152.232.247.173','40.77.167.235','85.208.96.206','190.99.23.153','102.38.1.172','155.133.78.47','73.149.160.222','64.67.107.176','66.249.70.192','45.176.235.213','85.81.42.41','79.106.215.227','103.181.127.136') )
0.000222 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9745'
0.000167 - SELECT * FROM bb_online WHERE (online_topic = '9745' AND online_uid <> '0')
0.000067 - SELECT * FROM `users` WHERE uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000330 - SELECT * FROM bb_online WHERE online_uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000043 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000034 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000036 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000044 - SELECT groupid FROM groups_users_link WHERE uid=2020
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 958 AND rank_max >= 958 AND rank_special = 0
0.000037 - SELECT groupid FROM groups_users_link WHERE uid=1950
0.000037 - SELECT groupid FROM groups_users_link WHERE uid=2182
0.000034 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000033 - SELECT groupid FROM groups_users_link WHERE uid=1253
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 114 AND rank_max >= 114 AND rank_special = 0
0.000038 - SELECT post_id FROM bb_posts WHERE topic_id = 9745 AND pid = 0
0.000113 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 59
Usage de la mémoire: 9950352 bytes
XOOPS a mis 0.223 seconde(s) pour charger
