147 Personne(s) en ligne (88 Personne(s) connectée(s) sur Forum)
Invité(s): 147
« 1 2 3 (4) 5 6 7 ... 12 »
Post(s): 1175
tu m'etonne !!
Post(s): 958
rouler a 80km pas plus ptdr
De Vitry le françois
Post(s): 520
:lovemegane
Post(s): 520
:lovemegane
Post(s): 1001
Post(s): 1175
Post(s): 1001
+1
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
De 38
Post(s): 114
trés belle voiture
Mégane Coupé1.6 16s rsi :-)
Post(s): 958
il me faut 150litres par sub
Ca fait beaucoup.
Post(s): 958
Post(s): 958
0.000116 - SET NAMES 'utf8'
0.000991 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '31b4e2fdf14442ad704b350dc5bd26bd'
0.000486 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000307 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 227618
0.000055 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000034 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000380 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9745
0.000152 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000029 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1
0.000609 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1 AND post_id < 227618
0.000052 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9745 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.002372 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =9745
0.000138 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000147 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000110 - SELECT * FROM groups
0.000407 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.001062 - UPDATE online SET online_updated=1793908850, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000260 - SELECT * FROM online
0.000204 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000504 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000794 - UPDATE online SET online_updated=1793908850, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000150 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000693 - UPDATE bb_online SET online_updated= '1793908850', online_forum = '5', online_topic = '9745' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000308 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000942 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('207.46.13.127','201.4.71.213','157.22.100.211','31.105.109.61','83.244.49.143','80.233.70.177','115.84.115.199','31.105.112.95','71.105.205.202','41.182.143.40','52.167.144.156','91.126.106.160','109.81.12.155','123.16.202.184','81.110.17.38','37.67.207.22','148.71.243.30','92.71.61.7','207.219.35.10','185.187.130.189','85.208.96.209','152.232.128.135','192.101.67.43','85.208.96.199','88.218.44.219','202.46.61.93','212.171.138.43','165.165.115.254','185.191.171.3','94.226.168.18','161.0.246.119','85.208.96.207','85.208.96.202','85.208.96.201','176.201.212.10','217.204.65.81','79.106.212.29','95.10.229.153','181.23.91.67','160.154.247.195','91.186.242.240','38.236.106.93','185.46.174.79','189.253.51.110','113.160.76.232','213.204.127.6','103.42.228.86','144.76.23.205','193.202.13.27','85.164.200.250','41.141.37.71','216.73.216.84','103.166.100.84','185.191.171.5','185.191.171.18','185.191.171.9','46.11.214.174','122.8.45.63','185.21.138.46','216.73.216.244','5.192.98.247','207.215.130.43','201.69.48.122','85.208.96.194','102.223.157.229','47.37.20.72','88.218.47.23','103.174.194.215','181.32.126.7','41.125.85.209','157.55.39.195','89.153.201.192','88.182.239.235','202.46.62.36','83.108.18.130','85.208.96.206','177.200.32.189','66.9.171.28','51.174.9.72','178.210.225.83','66.249.64.8','105.74.128.10','94.240.22.44','186.52.146.75','185.54.158.166','177.93.0.15','45.189.217.81','37.242.55.226') )
0.000193 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9745'
0.000143 - SELECT * FROM bb_online WHERE (online_topic = '9745' AND online_uid <> '0')
0.000086 - SELECT * FROM `users` WHERE uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000233 - SELECT * FROM bb_online WHERE online_uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000067 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000027 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=2020
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 958 AND rank_max >= 958 AND rank_special = 0
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=1950
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=2182
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=1253
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 114 AND rank_max >= 114 AND rank_special = 0
0.000252 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000026 - SELECT post_id FROM bb_posts WHERE topic_id = 9745 AND pid = 0
0.000149 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 59
Usage de la mémoire: 9936680 bytes
XOOPS a mis 0.207 seconde(s) pour charger
