167 Personne(s) en ligne (138 Personne(s) connectée(s) sur Forum)
Invité(s): 167
« 1 2 3 (4) 5 6 7 ... 12 »
Post(s): 1175
tu m'etonne !!
Post(s): 958
rouler a 80km pas plus ptdr
De Vitry le françois
Post(s): 520
:lovemegane
Post(s): 520
:lovemegane
Post(s): 1001
Post(s): 1175
Post(s): 1001
+1
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
De 38
Post(s): 114
trés belle voiture
Mégane Coupé1.6 16s rsi :-)
Post(s): 958
il me faut 150litres par sub
Ca fait beaucoup.
Post(s): 958
Post(s): 958
0.000173 - SET NAMES 'utf8'
0.001142 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '7830337a28dcde812247066ebe3e08d8'
0.000909 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 226842
0.000054 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000060 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000050 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000200 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9745
0.000094 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000028 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1
0.000517 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1 AND post_id < 226842
0.000050 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9745 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.000289 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =9745
0.000253 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000198 - UPDATE online SET online_updated=1789931190, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000396 - SELECT * FROM online
0.000848 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000274 - UPDATE online SET online_updated=1789931190, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000147 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000423 - UPDATE bb_online SET online_updated= '1789931190', online_forum = '5', online_topic = '9745' WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000478 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001302 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('37.155.57.184','34.132.249.233','34.61.148.235','34.122.252.130','136.116.59.242','149.106.41.104','34.46.92.63','146.148.110.159','34.66.45.93','35.202.107.105','136.119.214.88','35.192.48.46','104.198.47.65','66.80.38.1','34.132.30.84','34.30.142.93','179.0.225.168','34.59.68.27','34.58.244.105','35.225.72.94','85.208.96.196','34.9.203.105','35.239.248.73','34.29.26.240','104.198.16.217','34.29.229.26','34.135.220.83','34.66.2.52','35.232.21.128','35.222.110.111','136.119.145.242','35.255.220.188','34.9.180.63','34.171.232.236','88.229.71.83','34.30.233.192','34.10.108.251','34.10.84.36','73.226.129.115','34.28.60.93','34.55.56.100','136.112.32.154','136.114.7.39','34.9.131.229','136.115.98.185','34.170.20.48','34.16.86.184','104.197.166.106','34.57.115.209','34.134.185.175','35.193.156.72','34.30.52.134','35.254.195.237','136.114.190.91','85.208.96.195','136.115.172.248','52.167.144.160','34.68.177.213','35.226.106.205','34.173.48.161','34.27.43.36','136.119.87.190','34.28.30.77','35.255.232.183','34.27.99.191','167.250.109.175','66.251.242.255','51.75.236.151','167.250.109.197','35.202.95.134','136.114.178.72','35.226.113.131','35.255.139.26','35.226.94.124','35.192.131.166','34.172.174.93','35.202.250.239','35.254.201.217','85.208.96.194','34.133.237.161','136.113.248.41','34.71.205.180','85.208.96.197','35.254.25.136','85.208.96.209','85.208.96.210','179.6.7.17','35.222.247.211','35.188.85.51','141.226.92.195','34.42.103.145','35.253.40.20','34.27.24.113','213.186.155.35','34.123.129.208','49.0.7.247','35.226.130.30','66.249.68.194','34.72.19.252','34.44.229.100','220.181.108.156','85.208.96.206','34.63.146.186','136.115.16.60','34.134.224.139','34.31.108.231','35.254.55.111','66.249.79.4','136.65.144.175','34.134.213.208','34.31.207.226','92.222.104.216','136.64.93.95','216.73.217.83','104.154.189.181','66.249.68.193','34.27.103.20','66.249.68.192','35.225.10.214','34.59.183.133','34.41.65.37','34.133.188.217','34.41.18.53','35.226.87.141','136.114.251.213','34.60.251.45','34.56.146.15','34.173.138.43','177.155.103.70','34.28.137.40','150.109.117.7','34.27.5.65','35.193.255.230','104.165.93.26','35.193.15.59','35.225.182.77','136.65.57.107','34.31.12.118') )
0.000195 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9745'
0.000138 - SELECT * FROM bb_online WHERE (online_topic = '9745' AND online_uid <> '0')
0.000080 - SELECT * FROM `users` WHERE uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000200 - SELECT * FROM bb_online WHERE online_uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000065 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000026 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000041 - SELECT groupid FROM groups_users_link WHERE uid=2020
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 958 AND rank_max >= 958 AND rank_special = 0
0.000055 - SELECT groupid FROM groups_users_link WHERE uid=1950
0.000050 - SELECT groupid FROM groups_users_link WHERE uid=2182
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 11
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000080 - SELECT groupid FROM groups_users_link WHERE uid=1253
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 114 AND rank_max >= 114 AND rank_special = 0
0.003490 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000032 - SELECT post_id FROM bb_posts WHERE topic_id = 9745 AND pid = 0
Total: 59
Usage de la mémoire: 9931920 bytes
