177 Personne(s) en ligne (145 Personne(s) connectée(s) sur Forum)
Invité(s): 177
« 1 2 3 (4) 5 6 7 ... 12 »
Post(s): 1175
tu m'etonne !!
Post(s): 958
rouler a 80km pas plus ptdr
De Vitry le françois
Post(s): 520
:lovemegane
Post(s): 520
:lovemegane
Post(s): 1001
Post(s): 1175
Post(s): 1001
+1
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
De 38
Post(s): 114
trés belle voiture
Mégane Coupé1.6 16s rsi :-)
Post(s): 958
il me faut 150litres par sub
Ca fait beaucoup.
Post(s): 958
Post(s): 958
0.000151 - SET NAMES 'utf8'
0.001814 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '35c42e30984894adfe237354a286251d'
0.000462 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 227898
0.000074 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000057 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000056 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000066 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9745
0.000045 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000046 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1
0.000770 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1 AND post_id < 227898
0.000079 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9745 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.000069 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000060 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000057 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000056 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000061 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000256 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000128 - UPDATE online SET online_updated=1789928740, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000288 - SELECT * FROM online
0.000413 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000167 - UPDATE online SET online_updated=1789928740, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000159 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000125 - UPDATE bb_online SET online_updated= '1789928740', online_forum = '5', online_topic = '9745' WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.001379 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('136.114.7.39','45.38.115.149','104.198.177.225','34.132.30.84','34.10.254.204','35.255.64.216','34.29.77.190','136.115.0.150','34.172.184.174','34.27.103.20','185.191.171.12','34.72.19.252','34.172.78.224','34.134.185.175','34.31.12.118','34.30.230.50','170.238.172.5','34.55.227.40','34.45.53.200','34.55.56.100','34.60.251.45','34.136.104.39','35.202.50.196','136.119.87.190','35.254.201.217','185.191.171.4','136.112.177.219','35.238.73.253','34.55.37.33','34.133.188.217','35.188.85.51','34.68.97.129','34.16.86.184','34.29.246.143','35.184.229.62','35.193.15.59','185.191.171.10','35.255.220.188','35.222.247.211','136.115.148.7','35.222.231.60','35.192.48.46','35.202.107.105','35.226.130.30','153.66.241.151','45.143.31.62','216.73.217.83','149.115.153.92','116.179.32.84','34.9.131.229','52.167.144.181','34.44.229.100','34.71.18.247','34.136.179.114','34.135.220.83','35.254.25.136','35.202.223.123','34.57.28.101','35.192.131.166','34.27.5.65','34.133.150.125','35.254.208.237','34.44.114.244','34.67.161.204','35.184.42.130','35.223.180.90','188.3.52.91','34.63.146.186','34.66.2.52','34.134.213.208','34.30.52.134','136.113.250.234','35.226.106.205','34.44.37.232','34.67.133.93','185.191.171.9','136.111.73.51','34.41.65.37','66.249.68.194','136.65.57.107','202.51.84.31','157.254.116.163','34.173.48.161','136.65.150.131','34.133.237.161','35.222.47.18','152.163.6.209','104.252.222.56','155.254.58.1','185.191.171.18','78.163.109.82','34.59.68.27','35.226.113.131','34.171.232.236','34.31.108.231','35.254.231.19','35.226.190.245','34.31.207.226','136.112.32.154','34.71.205.180','136.64.93.95','37.236.70.8','66.249.68.192','128.79.6.199','34.42.103.145','52.167.144.166','34.29.186.28','34.44.200.48','104.165.16.22','220.181.108.159','165.254.234.83','34.63.130.210','35.255.247.90','34.28.60.93','35.222.110.111','85.208.96.212','34.172.174.93','34.123.129.208','34.30.233.192','34.172.85.78','185.191.171.11','35.254.55.111','34.132.16.45','85.208.96.196','34.69.172.88','136.115.16.60','34.29.26.240','35.239.86.222','212.70.109.32','35.253.61.23','34.28.137.40','52.167.144.205','104.197.166.106','185.191.171.1','113.199.228.159','136.113.248.41','34.132.249.233','35.226.87.141','34.27.99.191','34.27.24.113','34.136.111.60','136.65.73.35','136.114.251.213','34.60.121.79','34.136.50.121') )
0.000184 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9745'
0.000152 - SELECT * FROM bb_online WHERE (online_topic = '9745' AND online_uid <> '0')
0.000090 - SELECT * FROM `users` WHERE uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000280 - SELECT * FROM bb_online WHERE online_uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000053 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000040 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000043 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000046 - SELECT groupid FROM groups_users_link WHERE uid=2020
0.000037 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 958 AND rank_max >= 958 AND rank_special = 0
0.000044 - SELECT groupid FROM groups_users_link WHERE uid=1950
0.000039 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000045 - SELECT groupid FROM groups_users_link WHERE uid=2182
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 11
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000045 - SELECT groupid FROM groups_users_link WHERE uid=1253
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 114 AND rank_max >= 114 AND rank_special = 0
0.000106 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000036 - SELECT post_id FROM bb_posts WHERE topic_id = 9745 AND pid = 0
Total: 58
Usage de la mémoire: 9935296 bytes
XOOPS a mis 0.259 seconde(s) pour charger
XOOPS output init a mis 0.074 seconde(s) pour charger
Module display a mis 0.093 seconde(s) pour charger
