110 Personne(s) en ligne (91 Personne(s) connectée(s) sur Forum)
Invité(s): 110
« 1 2 3 (4) 5 6 7 ... 12 »
Post(s): 1175
tu m'etonne !!
Post(s): 958
rouler a 80km pas plus ptdr
De Vitry le françois
Post(s): 520
:lovemegane
Post(s): 520
:lovemegane
Post(s): 1001
Post(s): 1175
Post(s): 1001
+1
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
De 38
Post(s): 114
trés belle voiture
Mégane Coupé1.6 16s rsi :-)
Post(s): 958
il me faut 150litres par sub
Ca fait beaucoup.
Post(s): 958
Post(s): 958
0.000127 - SET NAMES 'utf8'
0.000924 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '4a702ff3dd6ad42de8836f2c86fec3fa'
0.000381 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 227959
0.000081 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000076 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000206 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9745
0.000111 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000028 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1
0.000522 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1 AND post_id < 227959
0.001333 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9745 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.000294 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =9745
0.000945 - SELECT * FROM groups
0.001077 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000160 - UPDATE online SET online_updated=1793911217, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000228 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000323 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000152 - UPDATE online SET online_updated=1793911217, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000294 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000188 - UPDATE bb_online SET online_updated= '1793911217', online_forum = '5', online_topic = '9745' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000965 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('148.227.67.62','37.215.40.60','38.41.12.135','190.153.45.144','189.239.72.142','109.136.84.164','195.81.171.252','138.97.161.39','178.51.238.194','202.46.62.27','37.69.217.45','190.99.23.2','119.152.199.90','108.53.188.44','109.161.178.25','85.81.42.49','79.116.172.152','81.88.75.25','79.167.240.191','99.235.93.189','31.105.126.109','85.100.198.102','185.191.171.17','178.226.143.182','103.31.178.255','178.20.214.169','82.22.239.170','144.76.23.197','39.39.172.93','119.111.248.43','102.22.171.243','197.63.212.233','128.127.120.23','80.201.102.222','88.238.176.71','85.208.96.200','69.94.36.248','202.46.62.5','40.77.167.247','189.178.6.81','45.38.189.191','157.55.39.192','185.139.12.233','46.34.230.104','188.138.218.19','52.167.144.182','46.55.116.165','102.206.240.254','94.76.169.162','78.99.210.44','162.141.20.58','37.236.31.36','190.167.147.84','94.154.113.136','185.191.171.4','179.125.133.104','197.206.54.61','216.73.216.244','201.211.114.38','73.104.31.96','78.173.54.138','179.116.104.57','85.104.196.99','167.58.222.152','91.220.41.11','102.89.69.71','36.236.161.133','88.201.125.92','46.249.236.184','185.191.171.6','85.208.96.194','85.208.96.210','85.208.96.209','94.187.23.75','50.117.66.255','156.201.140.216','195.135.246.197','186.109.154.164','177.37.42.218','114.130.187.225','187.198.120.191','145.223.2.163','177.18.111.200','5.29.20.88','130.193.229.37','102.97.32.15','39.63.199.218','191.179.62.78','181.98.244.82','85.208.96.198','85.208.96.205') )
0.000175 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9745'
0.000120 - SELECT * FROM bb_online WHERE (online_topic = '9745' AND online_uid <> '0')
0.000387 - SELECT * FROM `users` WHERE uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000212 - SELECT * FROM bb_online WHERE online_uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000044 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000027 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000026 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000067 - SELECT groupid FROM groups_users_link WHERE uid=2020
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 958 AND rank_max >= 958 AND rank_special = 0
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=1950
0.000047 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000067 - SELECT groupid FROM groups_users_link WHERE uid=2182
0.000093 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=1253
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 114 AND rank_max >= 114 AND rank_special = 0
0.000118 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000026 - SELECT post_id FROM bb_posts WHERE topic_id = 9745 AND pid = 0
Total: 59
Usage de la mémoire: 9933568 bytes
XOOPS a mis 0.242 seconde(s) pour charger
Page rendering a mis 0.084 seconde(s) pour charger
