121 Personne(s) en ligne (84 Personne(s) connectée(s) sur Forum)
Invité(s): 121
« 1 2 3 (4) 5 6 7 ... 12 »
Post(s): 1175
tu m'etonne !!
Post(s): 958
rouler a 80km pas plus ptdr
De Vitry le françois
Post(s): 520
:lovemegane
Post(s): 520
:lovemegane
Post(s): 1001
Post(s): 1175
Post(s): 1001
+1
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
De 38
Post(s): 114
trés belle voiture
Mégane Coupé1.6 16s rsi :-)
Post(s): 958
il me faut 150litres par sub
Ca fait beaucoup.
Post(s): 958
Post(s): 958
0.000183 - SET NAMES 'utf8'
0.001099 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'f9a634c58507bb8e2215341af8bf45be'
0.000296 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 226450
0.000095 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000081 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000051 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000304 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9745
0.000353 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000205 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1
0.000669 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1 AND post_id < 226450
0.001830 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9745 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.000069 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000118 - SELECT * FROM groups
0.000296 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000384 - UPDATE online SET online_updated=1793910531, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000461 - SELECT * FROM online
0.000710 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000253 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000169 - UPDATE online SET online_updated=1793910531, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000202 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000353 - UPDATE bb_online SET online_updated= '1793910531', online_forum = '5', online_topic = '9745' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000445 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001191 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('171.225.14.170','109.60.91.88','85.208.96.194','38.191.35.210','85.208.96.209','85.208.96.203','193.202.80.170','45.147.11.180','176.29.160.15','151.250.71.47','197.221.251.158','176.43.221.15','91.92.87.236','45.169.251.140','92.251.67.95','186.121.167.110','196.70.199.182','153.68.226.20','102.66.187.24','132.255.113.190','66.249.64.8','79.132.5.242','177.170.225.242','45.233.196.218','37.142.186.154','31.105.105.135','85.208.96.208','185.191.171.13','92.74.186.221','86.131.69.43','186.14.0.115','45.230.39.122','66.249.70.192','91.82.240.128','80.201.102.222','152.232.243.223','45.140.207.150','82.197.48.240','37.114.154.206','196.235.221.35','185.191.171.15','86.177.112.223','185.191.171.11','102.249.40.0','181.116.56.171','138.36.213.38','91.106.43.51','190.212.216.25','102.138.53.21','41.158.172.230','213.6.102.191','102.107.140.142','202.46.62.70','62.250.202.12','179.60.84.55','185.191.171.6','41.200.182.152','182.52.152.138','38.25.25.72','102.254.103.0','216.73.216.244','35.150.223.135','66.9.171.28','212.130.187.28','110.38.12.86','122.129.95.47','102.204.153.93','89.89.242.177','78.190.253.115','181.188.46.71','152.232.129.126','185.191.171.4','45.230.168.67','38.236.224.120','94.9.166.215','103.181.72.7','45.186.53.192','147.236.165.27','41.248.127.184','72.50.3.149','144.124.193.15','77.243.26.99','99.237.40.246','45.180.22.171') )
0.000255 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9745'
0.000268 - SELECT * FROM bb_online WHERE (online_topic = '9745' AND online_uid <> '0')
0.000758 - SELECT * FROM `users` WHERE uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000246 - SELECT * FROM bb_online WHERE online_uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000041 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000026 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=2020
0.000062 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 958 AND rank_max >= 958 AND rank_special = 0
0.000142 - SELECT groupid FROM groups_users_link WHERE uid=1950
0.000042 - SELECT groupid FROM groups_users_link WHERE uid=2182
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 11
0.000053 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000058 - SELECT groupid FROM groups_users_link WHERE uid=1253
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 114 AND rank_max >= 114 AND rank_special = 0
0.000092 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000041 - SELECT post_id FROM bb_posts WHERE topic_id = 9745 AND pid = 0
Total: 58
Usage de la mémoire: 9940976 bytes
XOOPS a mis 0.380 seconde(s) pour charger
XOOPS Boot a mis 0.075 seconde(s) pour charger
XOOPS output init a mis 0.104 seconde(s) pour charger
Module display a mis 0.115 seconde(s) pour charger
