154 Personne(s) en ligne (94 Personne(s) connectée(s) sur Forum)
Invité(s): 154
« 1 2 3 (4) 5 6 7 ... 12 »
Post(s): 1175
tu m'etonne !!
Post(s): 958
rouler a 80km pas plus ptdr
De Vitry le françois
Post(s): 520
:lovemegane
Post(s): 520
:lovemegane
Post(s): 1001
Post(s): 1175
Post(s): 1001
+1
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
De 38
Post(s): 114
trés belle voiture
Mégane Coupé1.6 16s rsi :-)
Post(s): 958
il me faut 150litres par sub
Ca fait beaucoup.
Post(s): 958
Post(s): 958
0.000112 - SET NAMES 'utf8'
0.000531 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '3ba7be1df633a67a74df9235e038fad9'
0.000404 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 227834
0.000059 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000069 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000221 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9745
0.000305 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000030 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1
0.000577 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1 AND post_id < 227834
0.000043 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9745 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.000117 - SELECT * FROM groups
0.000128 - SELECT * FROM bb_forums ORDER BY forum_order
0.000068 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000412 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000578 - UPDATE online SET online_updated=1793908892, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000095 - -300
0.000260 - DELETE FROM online WHERE online_updated < 1793908592
0.000141 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000177 - UPDATE online SET online_updated=1793908892, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000141 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000323 - UPDATE bb_online SET online_updated= '1793908892', online_forum = '5', online_topic = '9745' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000190 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000998 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('201.4.71.213','157.22.100.211','31.105.109.61','83.244.49.143','80.233.70.177','115.84.115.199','31.105.112.95','71.105.205.202','41.182.143.40','52.167.144.156','154.71.159.57','91.126.106.160','109.81.12.155','123.16.202.184','172.58.3.57','81.110.17.38','37.67.207.22','148.71.243.30','92.71.61.7','207.219.35.10','86.15.111.84','185.187.130.189','85.208.96.209','85.208.96.200','152.232.128.135','192.101.67.43','190.92.22.58','81.254.128.68','88.218.44.219','202.46.61.93','212.171.138.43','165.165.115.254','185.191.171.3','94.226.168.18','161.0.246.119','85.208.96.207','85.208.96.202','85.208.96.201','176.201.212.10','217.204.65.81','79.106.212.29','95.10.229.153','181.23.91.67','160.154.247.195','91.186.242.240','38.236.106.93','185.46.174.79','189.253.51.110','113.160.76.232','213.204.127.6','103.42.228.86','45.147.234.38','193.202.13.27','85.164.200.250','41.141.37.71','216.73.216.84','103.166.100.84','185.191.171.5','185.191.171.18','46.11.214.174','122.8.45.63','185.21.138.46','216.73.216.244','185.215.54.40','5.192.98.247','207.215.130.43','201.69.48.122','85.208.96.194','102.223.157.229','47.37.20.72','88.218.47.23','103.174.194.215','181.32.126.7','41.125.85.209','89.153.201.192','88.182.239.235','202.46.62.36','83.108.18.130','66.249.70.193','201.247.15.61','85.208.96.206','177.200.32.189','94.76.169.201','66.9.171.28','51.174.9.72','178.210.225.83','66.249.64.8','105.74.128.10','94.240.22.44','186.52.146.75','185.54.158.166','177.93.0.15','45.189.217.81','37.242.55.226') )
0.000151 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9745'
0.000118 - SELECT * FROM bb_online WHERE (online_topic = '9745' AND online_uid <> '0')
0.000084 - SELECT * FROM `users` WHERE uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000214 - SELECT * FROM bb_online WHERE online_uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000028 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000024 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=2020
0.000039 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 958 AND rank_max >= 958 AND rank_special = 0
0.000069 - SELECT groupid FROM groups_users_link WHERE uid=1950
0.000069 - SELECT groupid FROM groups_users_link WHERE uid=2182
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 11
0.000032 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000032 - SELECT groupid FROM groups_users_link WHERE uid=1253
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 114 AND rank_max >= 114 AND rank_special = 0
0.000074 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000025 - SELECT post_id FROM bb_posts WHERE topic_id = 9745 AND pid = 0
Total: 60
Usage de la mémoire: 9941216 bytes
