52 Personne(s) en ligne (38 Personne(s) connectée(s) sur Forum)
Invité(s): 52
« 1 2 3 (4) 5 6 7 ... 12 »
Post(s): 1175
tu m'etonne !!
Post(s): 958
rouler a 80km pas plus ptdr
De Vitry le françois
Post(s): 520
:lovemegane
Post(s): 520
:lovemegane
Post(s): 1001
Post(s): 1175
Post(s): 1001
+1
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
De 38
Post(s): 114
trés belle voiture
Mégane Coupé1.6 16s rsi :-)
Post(s): 958
il me faut 150litres par sub
Ca fait beaucoup.
Post(s): 958
Post(s): 958
0.000185 - SET NAMES 'utf8'
0.000140 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001256 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '175556212bf6ae49d90f07b83595fcfa'
0.000441 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 226883
0.000061 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000044 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000299 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9745
0.000147 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000041 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1
0.000848 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1 AND post_id < 226883
0.000055 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9745 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.000046 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000327 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.172'
0.001140 - UPDATE online SET online_updated=1779715779, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.172'
0.000169 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000481 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.172'
0.000999 - UPDATE online SET online_updated=1779715779, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.172'
0.000236 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.172'
0.000386 - UPDATE bb_online SET online_updated= '1779715779', online_forum = '5', online_topic = '9745' WHERE online_uid = 0 AND online_ip='216.73.217.172'
0.000689 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('66.249.66.164','66.249.66.69','66.249.66.5','74.101.28.225','185.191.171.14','194.187.171.132','51.195.215.255','116.179.32.31','51.195.215.228','85.208.96.211','85.208.96.201','51.195.215.100','104.28.156.60','66.249.66.166','85.208.96.196','66.249.66.6','51.195.183.222','51.195.215.104','66.249.66.77','51.89.129.13','51.195.215.18','86.192.92.15','66.249.66.165','66.249.66.32','66.249.66.68','40.77.167.41','54.38.147.85','54.38.147.224','66.249.66.34','198.244.242.33','66.249.66.33','66.249.66.192','66.249.66.193','198.244.183.13','54.38.147.213','51.89.129.218','216.73.217.172','54.38.147.229') )
0.000238 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9745'
0.000191 - SELECT * FROM bb_online WHERE (online_topic = '9745' AND online_uid <> '0')
0.000081 - SELECT * FROM `users` WHERE uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000240 - SELECT * FROM bb_online WHERE online_uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000051 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000040 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000050 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000050 - SELECT groupid FROM groups_users_link WHERE uid=2020
0.000037 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 958 AND rank_max >= 958 AND rank_special = 0
0.000046 - SELECT groupid FROM groups_users_link WHERE uid=1950
0.000037 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000056 - SELECT groupid FROM groups_users_link WHERE uid=2182
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 11
0.000045 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000046 - SELECT groupid FROM groups_users_link WHERE uid=1253
0.000034 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 114 AND rank_max >= 114 AND rank_special = 0
0.000120 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000041 - SELECT post_id FROM bb_posts WHERE topic_id = 9745 AND pid = 0
Total: 58
Usage de la mémoire: 9927288 bytes
