121 Personne(s) en ligne (87 Personne(s) connectée(s) sur Forum)
Invité(s): 121
« 1 2 3 (4) 5 6 7 ... 12 »
Post(s): 1175
tu m'etonne !!
Post(s): 958
rouler a 80km pas plus ptdr
De Vitry le françois
Post(s): 520
:lovemegane
Post(s): 520
:lovemegane
Post(s): 1001
Post(s): 1175
Post(s): 1001
+1
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
De 38
Post(s): 114
trés belle voiture
Mégane Coupé1.6 16s rsi :-)
Post(s): 958
il me faut 150litres par sub
Ca fait beaucoup.
Post(s): 958
Post(s): 958
0.000155 - SET NAMES 'utf8'
0.001303 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '90ebc4aafa2249cbf66b83d3c5446730'
0.000364 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 226873
0.000065 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000050 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000049 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9745
0.000033 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000029 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1
0.000564 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1 AND post_id < 226873
0.000065 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9745 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.000076 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000074 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000182 - SELECT * FROM bb_forums ORDER BY forum_order
0.000293 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000381 - UPDATE online SET online_updated=1793908189, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000149 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000228 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000574 - UPDATE online SET online_updated=1793908189, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000181 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000766 - UPDATE bb_online SET online_updated= '1793908189', online_forum = '5', online_topic = '9745' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000841 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('146.255.74.188','51.194.196.20','41.125.255.42','82.167.214.23','77.46.129.173','136.158.61.103','189.244.21.13','172.58.3.57','102.22.140.32','41.90.66.113','188.161.211.83','185.191.171.15','37.236.31.34','152.232.187.183','179.101.181.163','92.71.12.92','104.164.59.165','85.208.96.195','155.212.109.49','194.77.192.125','92.253.4.98','85.208.96.210','187.191.38.32','52.167.144.173','207.216.205.195','152.232.241.165','202.46.62.96','82.42.18.213','207.46.13.127','190.115.67.84','161.0.154.77','201.247.15.61','188.149.210.52','185.191.171.11','212.81.52.143','51.36.175.83','171.225.206.168','138.219.212.106','102.31.188.101','103.60.88.13','176.28.172.22','66.249.64.7','93.140.80.213','85.208.96.199','188.70.14.227','84.251.39.202','69.94.45.234','117.1.201.141','79.126.113.226','151.244.152.177','144.76.23.204','147.235.197.213','86.161.183.94','62.201.243.9','24.188.73.210','77.249.56.215','216.73.216.84','77.141.37.114','85.208.96.194','197.234.87.122','195.81.101.149','38.62.92.246','153.67.161.192','170.168.241.31','170.168.98.220','102.221.169.47','147.235.197.197','203.168.150.141','185.191.171.1','9.246.77.143','83.167.40.95','197.204.177.62','200.71.122.182','85.208.96.211','185.191.171.16','86.108.23.158','212.142.106.186','176.28.174.224','66.249.70.202','87.15.241.104','93.202.32.229','85.252.223.77','160.179.131.198','84.54.139.62','178.157.32.95','82.146.21.17','185.122.252.43') )
0.000176 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9745'
0.000268 - SELECT * FROM bb_online WHERE (online_topic = '9745' AND online_uid <> '0')
0.000104 - SELECT * FROM `users` WHERE uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000250 - SELECT * FROM bb_online WHERE online_uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000070 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000030 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000064 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
0.001009 - SELECT groupid FROM groups_users_link WHERE uid=2020
0.000037 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 958 AND rank_max >= 958 AND rank_special = 0
0.000069 - SELECT groupid FROM groups_users_link WHERE uid=1950
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000072 - SELECT groupid FROM groups_users_link WHERE uid=2182
0.000030 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 11
0.000071 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000075 - SELECT groupid FROM groups_users_link WHERE uid=1253
0.000030 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 114 AND rank_max >= 114 AND rank_special = 0
0.000725 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000054 - SELECT post_id FROM bb_posts WHERE topic_id = 9745 AND pid = 0
Total: 58
Usage de la mémoire: 9933952 bytes
XOOPS a mis 0.246 seconde(s) pour charger
