71 Personne(s) en ligne (53 Personne(s) connectée(s) sur Forum)
Invité(s): 71
« 1 2 3 (4) 5 6 7 ... 12 »
Post(s): 1175
tu m'etonne !!
Post(s): 958
rouler a 80km pas plus ptdr
De Vitry le françois
Post(s): 520
:lovemegane
Post(s): 520
:lovemegane
Post(s): 1001
Post(s): 1175
Post(s): 1001
+1
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
De 38
Post(s): 114
trés belle voiture
Mégane Coupé1.6 16s rsi :-)
Post(s): 958
il me faut 150litres par sub
Ca fait beaucoup.
Post(s): 958
Post(s): 958
0.000148 - SET NAMES 'utf8'
0.001368 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '97856155d8d0a7cfc29a5e0748eb9811'
0.000132 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000313 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 227846
0.000066 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000054 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000282 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9745
0.000233 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000030 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1
0.000766 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1 AND post_id < 227846
0.002145 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9745 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.000046 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000442 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000820 - UPDATE online SET online_updated=1793911979, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000258 - SELECT * FROM online
0.000255 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000395 - UPDATE online SET online_updated=1793911979, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000158 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000235 - UPDATE bb_online SET online_updated= '1793911979', online_forum = '5', online_topic = '9745' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000580 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('85.208.96.208','115.66.14.176','93.119.105.205','185.61.216.154','85.144.208.14','190.113.114.79','45.140.206.43','74.14.2.88','185.191.171.8','202.46.61.95','45.135.3.109','210.204.118.45','212.118.20.114','185.191.171.12','94.27.130.210','89.19.35.181','185.201.137.24','109.174.165.178','185.191.171.11','84.214.87.117','196.207.231.78','14.169.248.88','50.68.96.128','185.191.171.10','140.235.3.23','79.167.240.191','94.187.19.111','2.15.119.35','103.96.71.174','197.14.200.165','160.179.208.15','196.176.230.237','216.73.216.244','85.250.179.194','85.208.96.204','60.92.13.187','31.105.115.53','212.140.123.159','90.215.99.241','185.191.171.7','90.168.71.83','66.249.70.202','86.41.210.144','93.152.84.246','85.208.96.206','137.220.85.191','148.227.67.81','193.202.15.28','185.191.171.5','62.162.133.77','222.150.67.32','176.223.47.205','178.114.147.105') )
0.000158 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9745'
0.000201 - SELECT * FROM bb_online WHERE (online_topic = '9745' AND online_uid <> '0')
0.000427 - SELECT * FROM `users` WHERE uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000212 - SELECT * FROM bb_online WHERE online_uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000072 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000028 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000027 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000072 - SELECT groupid FROM groups_users_link WHERE uid=2020
0.000027 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 958 AND rank_max >= 958 AND rank_special = 0
0.000070 - SELECT groupid FROM groups_users_link WHERE uid=1950
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=2182
0.000088 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=1253
0.000033 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 114 AND rank_max >= 114 AND rank_special = 0
0.000074 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000045 - SELECT post_id FROM bb_posts WHERE topic_id = 9745 AND pid = 0
Total: 58
Usage de la mémoire: 9940832 bytes
XOOPS a mis 0.322 seconde(s) pour charger
XOOPS output init a mis 0.141 seconde(s) pour charger
