80 Personne(s) en ligne (46 Personne(s) connectée(s) sur Forum)
Invité(s): 80
« 1 2 3 (4) 5 6 7 ... 12 »
Post(s): 1175
tu m'etonne !!
Post(s): 958
rouler a 80km pas plus ptdr
De Vitry le françois
Post(s): 520
:lovemegane
Post(s): 520
:lovemegane
Post(s): 1001
Post(s): 1175
Post(s): 1001
+1
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
Post(s): 958
De 38
Post(s): 114
trés belle voiture
Mégane Coupé1.6 16s rsi :-)
Post(s): 958
il me faut 150litres par sub
Ca fait beaucoup.
Post(s): 958
Post(s): 958
0.000187 - SET NAMES 'utf8'
0.000051 - SET SQL_BIG_SELECTS = 1
0.001045 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'c848bdafae0c3f9be3bb397ef6fa59e9'
0.000349 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000087 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000065 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000241 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9745
0.000025 - SELECT * FROM bb_topics WHERE topic_id=9745
0.000028 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9745 AND approved = 1
0.001453 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9745 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.000665 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =9745
0.000096 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000292 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000328 - SELECT * FROM bb_forums ORDER BY forum_order
0.000237 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000874 - UPDATE online SET online_updated=1793908621, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000362 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000178 - UPDATE online SET online_updated=1793908622, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000141 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001161 - UPDATE bb_online SET online_updated= '1793908622', online_forum = '5', online_topic = '9745' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000521 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('170.168.28.217','207.46.13.127','193.151.191.206','185.191.171.5','83.25.228.167','52.167.144.156','201.207.239.31','104.205.80.210','40.77.167.235','185.191.171.3','62.107.16.165','130.49.115.203','185.191.171.15','85.208.96.199','154.110.187.136','73.155.200.250','130.49.115.168','190.62.84.80','94.122.146.109','85.208.96.211','181.230.68.49','177.91.82.42','88.162.13.6','31.134.15.200','202.46.62.38','79.126.113.226','144.76.23.205','193.202.13.27','197.221.251.55','41.158.199.196','77.243.26.99','216.73.216.84','146.19.91.104','185.191.171.9','209.212.210.98','2.125.42.76','79.106.215.227','90.215.42.239','41.143.5.147','5.175.146.252','77.98.26.42','157.55.39.195','77.249.56.215','202.46.62.117','104.165.74.239','185.191.171.2') )
0.000186 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9745'
0.000302 - SELECT * FROM bb_online WHERE (online_topic = '9745' AND online_uid <> '0')
0.000455 - SELECT * FROM `users` WHERE uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000228 - SELECT * FROM bb_online WHERE online_uid IN (3784,4282,2020,1950,2182,3711,1253)
0.000070 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000037 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000034 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000049 - SELECT groupid FROM groups_users_link WHERE uid=2020
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 958 AND rank_max >= 958 AND rank_special = 0
0.000435 - SELECT groupid FROM groups_users_link WHERE uid=1950
0.000057 - SELECT groupid FROM groups_users_link WHERE uid=2182
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000047 - SELECT groupid FROM groups_users_link WHERE uid=1253
0.000030 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 114 AND rank_max >= 114 AND rank_special = 0
0.000027 - SELECT post_id FROM bb_posts WHERE topic_id = 9745 AND pid = 0
0.000437 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 58
Usage de la mémoire: 9958688 bytes
