111 Personne(s) en ligne (70 Personne(s) connectée(s) sur Forum)
Invité(s): 111
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000122 - SET NAMES 'utf8'
0.001067 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'a21033cac49ceaac08b650ba9d2de00c'
0.000351 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 313301
0.000053 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000042 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000223 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000158 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000036 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000325 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 313301
0.000811 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000367 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000193 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000289 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.138'
0.001124 - UPDATE online SET online_updated=1793995942, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.138'
0.000239 - SELECT * FROM online
0.000302 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.138'
0.000151 - UPDATE online SET online_updated=1793995942, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.138'
0.000195 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.138'
0.000223 - UPDATE bb_online SET online_updated= '1793995942', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.138'
0.000688 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('31.22.93.40','1.92.192.4','130.49.11.132','192.178.7.162','50.61.6.18','178.115.155.142','192.178.6.128','87.134.151.209','190.143.191.41','188.173.209.198','94.187.18.104','41.108.131.102','185.173.205.47','195.81.136.127','119.28.108.51','81.70.254.170','190.212.205.15','216.73.216.138','152.232.128.150','31.105.98.107','95.142.92.154','115.186.241.25','178.121.26.134','43.154.160.183','46.9.46.71','89.41.65.214','154.8.204.201','23.230.61.148','37.65.43.244','190.62.86.247','109.247.139.107','190.61.50.250','102.0.7.26','196.77.26.51','43.143.163.162','178.168.19.16','78.101.211.107','195.64.249.24','92.209.216.149','189.1.218.249','140.206.235.101','43.153.30.211','202.46.62.55','93.146.168.191','179.6.100.246','43.156.152.220','61.216.175.250','202.46.62.32','174.168.119.85','151.225.186.1','168.222.90.78','5.77.142.183','31.105.124.124','172.83.252.59','186.119.186.184','113.44.121.18','82.174.75.134','170.168.240.183','129.226.51.236','179.25.242.39','116.204.67.8','43.156.244.246','122.8.92.71','105.232.176.216','217.204.67.223','217.204.67.28','202.46.62.23','196.170.78.165','81.70.186.71','62.217.142.113') )
0.000165 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000199 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000424 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000239 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000036 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 8350 AND rank_max >= 8350 AND rank_special = 0
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000045 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000043 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000028 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000026 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000125 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000028 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Total: 63
Usage de la mémoire: 10067664 bytes
XOOPS a mis 0.228 seconde(s) pour charger
