108 Personne(s) en ligne (53 Personne(s) connectée(s) sur Forum)
Invité(s): 108
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000109 - SET NAMES 'utf8'
0.001046 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '7ef86ca94304de2a65f2e844b48f4485'
0.000362 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 317527
0.001280 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000085 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000065 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.042138 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000555 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000125 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000073 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000444 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 317527
0.000357 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000507 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000259 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000056 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000083 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000752 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000084 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.001382 - DELETE FROM online WHERE online_updated < 1793995814
0.000275 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.138'
0.000500 - UPDATE online SET online_updated=1793996114, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.138'
0.000412 - SELECT * FROM online
0.000159 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000296 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.138'
0.001059 - UPDATE online SET online_updated=1793996114, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.138'
0.000239 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.138'
0.000960 - UPDATE bb_online SET online_updated= '1793996114', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.138'
0.000340 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000654 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('196.250.93.136','85.245.120.65','77.229.148.120','80.221.252.193','66.229.1.140','104.165.74.60','176.126.111.139','178.20.215.56','144.76.23.205','87.134.151.209','190.143.191.41','202.46.62.101','41.108.131.102','185.173.205.47','195.81.136.127','119.28.108.51','81.70.254.170','83.167.40.95','71.71.45.159','216.73.216.138','217.204.62.83','95.142.92.154','115.186.241.25','178.121.26.134','217.145.225.232','89.41.65.214','154.8.204.201','23.230.61.148','37.65.43.244','109.247.139.107','102.0.7.26','78.58.119.131','195.64.249.24','92.209.216.149','177.227.109.232','202.46.62.55','93.146.168.191','202.46.62.32','174.168.119.85','151.225.186.1','168.222.90.78','31.105.124.124','172.83.252.59','198.58.10.32','202.46.62.103','45.148.126.21','129.226.51.236','179.25.242.39','116.204.67.8','43.156.244.246','122.8.92.71','105.232.176.216','185.168.29.140') )
0.000212 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000128 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000084 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000252 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000040 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000134 - SELECT * FROM smiles
0.000040 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000056 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000060 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000040 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000041 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000028 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000031 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000052 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000027 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000030 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.001251 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000082 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000032 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Usage de la mémoire: 10068792 bytes
XOOPS a mis 0.472 seconde(s) pour charger
Module init a mis 0.065 seconde(s) pour charger
XOOPS output init a mis 0.124 seconde(s) pour charger
Module display a mis 0.165 seconde(s) pour charger
