175 Personne(s) en ligne (114 Personne(s) connectée(s) sur Forum)
Invité(s): 175
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000112 - SET NAMES 'utf8'
0.001076 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '5b3a57413685608ac01d11bd2c3643b3'
0.000362 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 314573
0.000058 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000035 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000247 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000106 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000446 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000260 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 314573
0.000822 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000499 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000296 - DELETE FROM online WHERE online_updated < 1793907384
0.000229 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000150 - UPDATE online SET online_updated=1793907684, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000269 - SELECT * FROM online
0.000277 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000145 - UPDATE online SET online_updated=1793907684, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000159 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000161 - UPDATE bb_online SET online_updated= '1793907684', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000265 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001110 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('179.215.126.107','200.105.212.45','95.5.66.176','91.219.254.81','81.240.54.18','105.197.48.218','72.255.18.243','14.237.82.76','181.119.64.182','105.118.74.35','77.223.238.94','177.226.79.215','85.208.96.206','172.58.3.57','40.77.167.24','81.108.39.67','190.62.84.80','88.92.255.14','94.165.158.37','195.87.234.234','85.29.235.182','190.142.81.212','105.113.70.214','171.97.28.37','14.174.76.124','101.108.5.19','200.195.112.9','109.63.93.69','38.210.226.8','140.235.171.109','168.232.161.195','108.6.148.69','144.76.23.194','171.252.225.175','102.161.221.187','202.46.62.47','45.143.207.159','206.180.143.95','41.251.29.2','213.230.87.196','202.46.62.33','179.6.171.180','161.0.154.77','185.191.171.11','80.217.238.224','66.249.70.192','188.22.100.251','59.91.213.236','89.147.166.138','83.167.40.95','170.168.29.55','160.202.35.170','68.228.146.146','167.148.214.77','202.46.61.99','39.50.156.34','38.137.177.218','84.213.1.230','84.229.108.167','113.183.72.38','38.51.12.243','105.101.35.79','103.26.80.197','193.202.9.98','185.142.40.218','88.10.109.60','51.36.207.167','66.249.64.7','197.121.249.69','148.63.139.122','216.73.216.84','185.191.171.6','177.226.134.196','82.76.49.160','185.191.171.14','66.249.64.8','89.150.154.20','84.109.40.110','207.46.13.130','185.201.136.121','85.208.96.193','185.191.171.12','147.235.197.197','87.241.158.243','157.22.103.214','87.197.92.130','79.117.117.128','69.94.45.234','109.80.11.198','197.234.87.122','104.165.197.30','105.77.206.210','185.191.171.16','38.92.20.212','185.191.171.5','86.15.111.84','196.115.25.161','190.122.176.6','202.46.61.118','91.201.161.112','180.245.114.209','85.208.96.198','90.129.203.31','92.71.61.93','204.15.146.1','90.226.220.143','177.39.255.67','94.9.219.61','41.225.203.15','147.78.183.36','185.191.171.13','177.245.238.180','103.147.106.41','103.131.212.167') )
0.000164 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000127 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000490 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000244 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000088 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000065 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000182 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000192 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000116 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000109 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000146 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000029 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000153 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000247 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Usage de la mémoire: 10074288 bytes
