133 Personne(s) en ligne (94 Personne(s) connectée(s) sur Forum)
Invité(s): 133
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000212 - SET NAMES 'utf8'
0.000128 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001549 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'd211d38354937b8c07a65125f7ff8a61'
0.000569 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 319049
0.000068 - SELECT * FROM bb_forums WHERE forum_id = 22
0.001034 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000124 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000036 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000400 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000145 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000042 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000520 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 319049
0.000071 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.001760 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000178 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000115 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000426 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001684 - UPDATE online SET online_updated=1793908243, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000291 - SELECT * FROM online
0.000306 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001499 - UPDATE online SET online_updated=1793908243, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000166 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001104 - UPDATE bb_online SET online_updated= '1793908243', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000263 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000951 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('146.255.74.188','51.194.196.20','41.125.255.42','82.167.214.23','77.46.129.173','136.158.61.103','189.244.21.13','172.58.3.57','102.22.140.32','41.90.66.113','188.161.211.83','185.191.171.15','37.236.31.34','152.232.187.183','37.65.29.118','179.101.181.163','185.191.171.5','74.125.210.195','46.176.153.53','202.46.62.106','155.212.109.49','194.77.192.125','92.253.4.98','85.208.96.210','187.191.38.32','52.167.144.173','207.216.205.195','152.232.241.165','202.46.62.96','82.42.18.213','207.46.13.127','190.115.67.84','161.0.154.77','179.6.23.166','201.247.15.61','188.149.210.52','185.191.171.10','185.191.171.11','212.81.52.143','51.36.175.83','171.225.206.168','138.219.212.106','102.31.188.101','103.60.88.13','176.28.172.22','66.249.64.7','93.140.80.213','85.208.96.199','188.70.14.227','84.251.39.202','69.94.45.234','117.1.201.141','79.126.113.226','151.244.152.177','144.76.23.204','147.235.197.213','86.161.183.94','62.201.243.9','24.188.73.210','216.73.216.84','217.74.152.235','77.141.37.114','85.208.96.194','66.249.70.193','197.234.87.122','195.81.101.149','38.62.92.246','153.67.161.192','79.117.117.128','167.59.173.238','170.245.1.62','102.221.169.47','147.235.197.197','203.168.150.141','185.191.171.1','9.246.77.143','83.167.40.95','197.204.177.62','200.71.122.182','62.194.37.24','128.127.120.23','185.191.171.16','86.108.23.158','212.142.106.186','176.28.174.224','66.249.70.202','87.15.241.104','93.202.32.229','85.252.223.77','160.179.131.198','84.54.139.62','178.157.32.95','82.146.21.17','185.122.252.43') )
0.000174 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000133 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000099 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000245 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.001366 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000067 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000954 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000065 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000065 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000026 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000022 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000023 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000051 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000120 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000030 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Total: 63
Usage de la mémoire: 10081032 bytes
XOOPS a mis 0.334 seconde(s) pour charger
Page rendering a mis 0.168 seconde(s) pour charger
