71 Personne(s) en ligne (52 Personne(s) connectée(s) sur Forum)
Invité(s): 71
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000116 - SET NAMES 'utf8'
0.000805 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001321 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '97856155d8d0a7cfc29a5e0748eb9811'
0.000405 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.001179 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 324180
0.000063 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000455 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000508 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000195 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000380 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000395 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 324180
0.000815 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000387 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000119 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000453 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000687 - UPDATE online SET online_updated=1793911944, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.024376 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000358 - UPDATE online SET online_updated=1793911944, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000183 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000425 - UPDATE bb_online SET online_updated= '1793911944', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000591 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('85.208.96.208','115.66.14.176','93.119.105.205','185.61.216.154','85.144.208.14','190.113.114.79','45.140.206.43','74.14.2.88','185.191.171.8','202.46.61.95','45.135.3.109','210.204.118.45','212.118.20.114','152.203.231.158','185.191.171.12','94.27.130.210','185.201.137.24','109.174.165.178','185.191.171.11','84.214.87.117','14.169.248.88','50.68.96.128','185.191.171.10','140.235.3.23','79.167.240.191','94.187.19.111','2.15.119.35','103.96.71.174','197.14.200.165','160.179.208.15','196.176.230.237','216.73.216.244','85.250.179.194','85.208.96.204','60.92.13.187','31.105.115.53','212.140.123.159','90.215.99.241','185.191.171.7','90.168.71.83','66.249.70.202','86.41.210.144','202.46.62.2','85.208.96.206','78.113.134.36','148.227.67.81','193.202.15.28','185.191.171.5','62.162.133.77','222.150.67.32','176.223.47.205','170.239.71.205') )
0.000164 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000196 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000864 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000223 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000057 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000073 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000093 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000049 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000212 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000387 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000295 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000039 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000046 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000033 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000027 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000827 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000378 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Total: 63
Usage de la mémoire: 10070512 bytes
XOOPS a mis 0.357 seconde(s) pour charger
Module init a mis 0.052 seconde(s) pour charger
Module display a mis 0.094 seconde(s) pour charger
Page rendering a mis 0.133 seconde(s) pour charger
