102 Personne(s) en ligne (71 Personne(s) connectée(s) sur Forum)
Invité(s): 102
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000175 - SET NAMES 'utf8'
0.000128 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.000985 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'e32f48643c0124cb480588f5585610fe'
0.000355 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 313344
0.000070 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000088 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000221 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000309 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000027 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000284 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 313344
0.000920 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000234 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000111 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000134 - SELECT * FROM bb_forums ORDER BY forum_order
0.000210 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000862 - UPDATE online SET online_updated=1793910754, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000281 - SELECT * FROM online
0.000249 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000128 - UPDATE online SET online_updated=1793910754, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000133 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000490 - UPDATE bb_online SET online_updated= '1793910754', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000208 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000769 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('66.249.70.202','170.247.193.112','202.46.61.99','66.249.64.7','192.177.138.194','41.74.138.65','193.202.87.184','85.208.96.203','42.0.7.238','193.202.80.170','45.147.11.180','23.230.22.247','92.17.71.38','45.88.13.80','37.214.3.24','176.202.190.61','59.103.90.14','176.223.60.8','176.64.10.248','209.198.130.13','185.61.222.48','147.78.161.255','190.88.244.219','85.208.96.208','83.182.100.110','190.252.174.6','102.220.14.200','185.132.251.90','102.64.161.123','66.249.70.192','202.46.61.64','83.97.116.156','88.97.197.159','85.208.96.211','185.191.171.11','217.204.62.227','187.110.233.106','90.15.245.154','193.32.76.91','118.179.39.1','169.224.104.97','188.52.129.28','181.10.182.250','103.135.253.194','95.70.223.222','65.92.188.138','88.242.203.31','216.73.216.244','90.163.41.71','93.172.169.71','119.93.153.253','148.222.119.171','154.110.228.36','176.6.10.197','154.39.145.191','165.165.116.70','172.59.208.181','185.191.171.14','202.46.62.13','37.133.166.89','112.201.130.123','74.244.163.203','185.154.3.182','152.232.176.97','37.236.180.234','93.152.77.190','31.134.7.113','83.105.143.155','185.168.30.221','77.220.194.60','85.208.96.198') )
0.000201 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000260 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000514 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000213 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000041 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000067 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000090 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000023 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000041 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000026 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000024 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000116 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000030 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
0.000059 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 63
Usage de la mémoire: 10075304 bytes
