81 Personne(s) en ligne (57 Personne(s) connectée(s) sur Forum)
Invité(s): 81
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000140 - SET NAMES 'utf8'
0.000154 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001204 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '3d3dc0dda4d499db330da20a02a3ad6d'
0.000274 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 318979
0.000057 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000147 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000247 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000514 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000544 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000335 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 318979
0.000834 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000442 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000113 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000198 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000420 - DELETE FROM online WHERE online_updated < 1793908959
0.000262 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000128 - UPDATE online SET online_updated=1793909259, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000383 - SELECT * FROM online
0.000154 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000342 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000189 - UPDATE online SET online_updated=1793909259, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000258 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000186 - UPDATE bb_online SET online_updated= '1793909259', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000293 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000909 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('83.85.235.55','85.208.96.196','185.191.171.19','202.46.62.94','85.208.96.208','94.21.240.49','51.174.9.72','83.97.117.120','185.68.153.68','37.243.39.150','129.224.207.4','85.208.96.200','86.13.249.24','83.253.241.81','92.118.14.95','118.179.27.177','85.208.96.209','168.227.166.59','194.1.216.13','85.208.96.193','136.35.165.92','166.114.130.54','103.109.56.165','102.209.29.151','182.62.58.145','93.121.235.92','64.43.63.112','162.141.4.130','151.244.152.177','185.191.171.18','181.78.245.75','89.184.61.194','190.191.191.41','185.191.171.11','185.191.171.12','103.170.152.221','185.101.21.107','216.73.216.244','170.80.62.101','197.186.5.45','188.155.248.138','103.121.173.52','41.182.143.40','85.208.96.194','83.167.40.95','5.241.139.159','177.198.141.87','105.100.23.107','78.190.144.45','168.197.83.179','191.178.192.69','31.105.105.148','66.9.171.28','102.205.217.10','130.49.113.20','51.175.91.126','90.233.195.169') )
0.000467 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000209 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.001038 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000300 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000047 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 8350 AND rank_max >= 8350 AND rank_special = 0
0.000141 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000051 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000219 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000388 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000041 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000029 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000022 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000020 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000022 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000027 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000063 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000367 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000563 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Usage de la mémoire: 10079848 bytes
