150 Personne(s) en ligne (92 Personne(s) connectée(s) sur Forum)
Invité(s): 150
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000112 - SET NAMES 'utf8'
0.001095 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '6ef639b2ad118bd83a0e81ba1748ec54'
0.000034 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000401 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 333234
0.000087 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000068 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000215 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000171 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000030 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000458 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 333234
0.000048 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000421 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000108 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000225 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000713 - UPDATE online SET online_updated=1793907796, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000393 - SELECT * FROM online
0.000241 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000216 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000102 - UPDATE online SET online_updated=1793907796, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000131 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000295 - UPDATE bb_online SET online_updated= '1793907796', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000181 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000974 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('179.215.126.107','200.105.212.45','95.5.66.176','91.219.254.81','81.240.54.18','105.197.48.218','72.255.18.243','14.237.82.76','181.119.64.182','105.118.74.35','77.223.238.94','177.226.79.215','85.208.96.206','172.58.3.57','40.77.167.24','81.108.39.67','190.62.84.80','88.92.255.14','94.165.158.37','195.87.234.234','85.29.235.182','190.142.81.212','105.113.70.214','171.97.28.37','14.174.76.124','101.108.5.19','200.195.112.9','109.63.93.69','38.210.226.8','140.235.171.109','168.232.161.195','31.105.116.123','216.40.75.104','52.167.144.173','102.161.221.187','202.46.62.47','45.143.207.159','206.180.143.95','41.251.29.2','104.252.46.205','185.191.171.11','66.249.70.192','59.91.213.236','185.188.190.210','207.46.13.141','91.204.51.251','82.21.236.38','194.1.216.13','85.208.96.204','185.142.40.218','88.10.109.60','51.36.207.167','66.249.64.7','92.41.50.111','216.73.216.84','92.124.162.108','185.191.171.6','177.226.134.196','82.76.49.160','66.249.64.8','89.150.154.20','202.46.62.104','207.46.13.130','185.201.136.121','85.208.96.193','147.235.197.197','85.208.96.199','157.22.103.214','87.197.92.130','79.117.117.128','34.44.156.213','109.80.11.198','197.234.87.122','85.208.96.211','197.2.86.221','185.191.171.16','38.92.20.212','185.191.171.5','77.175.99.249','202.46.61.118','91.201.161.112','180.245.114.209','85.208.96.198','90.129.203.31','92.71.61.93','204.15.146.1','185.191.171.18','41.225.203.15','84.178.182.31','199.101.189.165','177.245.238.180','103.131.212.167') )
0.000171 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000223 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000093 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000221 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000091 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000067 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000024 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000027 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000020 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000022 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000078 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000140 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000027 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Total: 63
Usage de la mémoire: 10109728 bytes
Module display a mis 0.057 seconde(s) pour charger
