124 Personne(s) en ligne (101 Personne(s) connectée(s) sur Forum)
Invité(s): 124
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000132 - SET NAMES 'utf8'
0.000126 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001066 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '716c31bc7e6c10ca6d7f62bfe185fd43'
0.000357 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 324184
0.000060 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000064 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000214 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000128 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000031 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000434 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 324184
0.001146 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000164 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000458 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001576 - UPDATE online SET online_updated=1793908096, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000171 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000461 - UPDATE online SET online_updated=1793908096, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000152 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001104 - UPDATE bb_online SET online_updated= '1793908096', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000183 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001007 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('146.255.74.188','51.194.196.20','41.125.255.42','82.167.214.23','77.46.129.173','136.158.61.103','189.244.21.13','172.58.3.57','102.22.140.32','41.90.66.113','188.161.211.83','185.191.171.15','37.236.31.34','152.232.187.183','179.101.181.163','92.71.12.92','104.164.59.165','85.208.96.195','92.253.4.98','85.208.96.210','187.191.38.32','52.167.144.173','185.81.144.73','207.216.205.195','152.232.241.165','202.46.62.96','82.42.18.213','207.46.13.127','190.115.67.84','161.0.154.77','31.105.120.31','170.245.1.62','83.194.44.102','84.127.0.115','196.207.227.206','187.143.100.139','185.191.171.11','212.81.52.143','51.36.175.83','171.225.206.168','138.219.212.106','102.31.188.101','103.60.88.13','176.28.172.22','66.249.64.7','93.140.80.213','85.208.96.199','188.70.14.227','47.72.75.67','82.108.130.98','89.19.35.142','69.94.45.234','117.1.201.141','85.75.98.211','103.207.83.167','144.76.23.204','147.235.197.213','92.41.50.111','190.72.32.230','192.140.92.212','77.249.56.215','216.73.216.84','45.15.132.23','190.171.113.137','77.141.37.114','85.208.96.194','84.115.228.123','177.226.134.196','197.234.87.122','195.81.101.149','38.62.92.246','31.105.105.204','153.67.161.192','170.168.241.31','170.168.98.220','85.208.96.193','102.221.169.47','147.235.197.197','203.168.150.141','185.191.171.1','9.246.77.143','83.167.40.95','197.204.177.62','200.71.122.182','85.208.96.211','185.191.171.16','86.108.23.158','212.142.106.186','31.134.9.62','66.249.70.202','185.191.171.8','85.252.223.77','75.198.21.33','213.230.78.181','84.54.139.62','178.157.32.95','82.146.21.17','185.61.20.244','92.208.63.146','45.179.248.199','185.122.252.43') )
0.000168 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000191 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000095 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000227 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000071 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000080 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000067 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000021 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000022 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000020 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000103 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000026 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Usage de la mémoire: 10080840 bytes
XOOPS a mis 0.260 seconde(s) pour charger
Page rendering a mis 0.115 seconde(s) pour charger
