91 Personne(s) en ligne (61 Personne(s) connectée(s) sur Forum)
Invité(s): 91
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000280 - SET NAMES 'utf8'
0.000113 - SET SQL_BIG_SELECTS = 1
0.001085 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '0d099c2b11f3b91cc53a429bb41110fe'
0.000104 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000068 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000296 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 317516
0.000053 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000074 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000353 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000205 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000033 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000382 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 317516
0.000065 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000258 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000636 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000407 - UPDATE online SET online_updated=1793907341, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000237 - SELECT * FROM online
0.000308 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000566 - UPDATE online SET online_updated=1793907341, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000159 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000453 - UPDATE bb_online SET online_updated= '1793907341', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000622 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('128.127.120.23','193.203.9.68','168.167.18.189','51.174.15.124','193.104.126.69','206.180.143.95','85.208.96.211','93.170.185.63','185.191.171.19','45.225.91.109','185.191.171.11','45.148.234.27','113.19.183.24','41.50.57.29','157.55.39.205','102.208.120.145','5.183.255.39','179.6.23.166','202.46.61.111','80.217.238.224','66.249.70.192','196.207.235.29','188.212.135.222','85.208.96.203','2.214.61.184','102.223.157.229','40.77.167.24','31.134.2.41','85.208.96.205','143.59.216.8','186.169.63.72','216.73.216.84','90.35.59.72','185.191.171.6','196.238.106.114','50.117.107.184','185.191.171.12','80.68.109.42','190.61.114.243','185.191.171.2','69.94.45.234','186.179.68.20','62.217.141.166','190.104.106.69','31.134.7.68','188.167.251.243','217.136.89.251','185.191.171.18','217.39.51.218','27.114.151.78','147.235.197.197','178.51.137.190','85.208.96.210','185.191.171.10','216.234.223.110','173.34.128.251','85.117.228.153','74.125.210.196','66.249.70.202','185.191.171.13','185.171.61.64') )
0.000151 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000176 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000085 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000228 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000043 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000070 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000028 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000019 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000024 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000020 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000023 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000139 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000061 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
0.000132 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 63
Usage de la mémoire: 10077240 bytes
XOOPS a mis 0.394 seconde(s) pour charger
Module init a mis 0.049 seconde(s) pour charger
XOOPS output init a mis 0.109 seconde(s) pour charger
Module display a mis 0.105 seconde(s) pour charger
Page rendering a mis 0.109 seconde(s) pour charger
